Any way to get d150 drop spindles?
Old Feb 21, 2008 | 02:34 PM
  #71
300hp318's Avatar
300hp318
Default RE: Any way to get d150 drop spindles?
just ordered 2' drop shackles from truckin supension 81$ shipped. if i figure out how to post pics ill put some up. my truck is a bit ugly but thats alright its gonna be a sleeper.
Old Feb 21, 2008 | 02:58 PM
  #72
daomen4ever's Avatar
daomen4ever
but do u know what kind of lowering
shock i can use for my 88 d100
Old Feb 21, 2008 | 07:19 PM
  #73
84 Ram's Avatar
84 Ram
I live in Kentucky. Is everyone else getting their products from Just Air Bag It?
Old Feb 21, 2008 | 11:14 PM
  #74
Rampant 150's Avatar
Rampant 150
Im checking out ebay. Found some shackles for around $50 shipped.
Old Feb 22, 2008 | 09:16 AM
  #75
turbododgepirate's Avatar
turbododgepirate
I see people mentioning Shackles. I know the truckinsuspension ones for 1978-93 part# SHA DO7893 Are $69 plus shipping.
I also see that their hangers are $99. Is that unreasonably high? Can we use another part, or are we stuck with that?
I posted previously about the shocks that I am using. I have the silverado shocks here and the rear air shocks are coming today.
I was also fairly disappointed to find out that I have the 5" bolt pattern on my 1985. Looks like wheels will be a little more difficult to find. A friend had dodge supercoupe wheels that would have been awesome.
Old Feb 22, 2008 | 08:56 PM
  #76
lugnuts's Avatar
lugnuts
ORIGINAL: turbododgepirate
Spindles didn't show up this week. The big bolt pattern is the same as a Ramcharger,[at least my '86,] and Ford P.U.,and some Jeeps. Opens up a few options if you spot a set of aftermarket wheels you like.
Old Feb 23, 2008 | 02:06 PM
  #77
lugnuts's Avatar
lugnuts
ORIGINAL: lugnuts
ORIGINAL: mrbelvedere
in 84 was when they went to that stupid bolt patteren and the different bearing in the inside of the rotor they all still use the same outside bearing but 84 up they use a different inside and the dakota spindle uses the same big inside bearing
Got '83 rotors on my '84, and they're 4 3/4. Got the wheels off the '83 on all four corners. The '83 was my previous hot rod till it got hit in the front. It lives on as a 3/4 ton after a frame swap from a '73!
Thought I was wrong once, but I was mistaken. They're 4 1/2"
Old Feb 24, 2008 | 08:02 PM
  #78
racer9's Avatar
racer9
It got clear up to 40* today, so I did some work on my truck.
I was going to leave the springs on top of the axle, and try to flatten them to lowerit. After much debate with my self, I convinced me to try the axle flip. I was amazed at how easily the bolts came out of the oem shackles. Thank God for southern trucks! I now have the axle on top of the springs. I just need to get the u-bolts, centerbolts, saddles, and make a plate.Then I can tear into the front end and cut those coils.
I think I'll get it down and only spend about $15-$20
I also found out my driveshaft rubbed something at some time and has a groove worn around it. New driveshaft time.
Then Istraightened a gas tank hanger bracket, which looked as if someone hung it up on a stump somewhere. It too unbolted easily. The tank has dent in it, which I'm hoping will push itself out when summer comes and I fill it up.
When I get it back on the ground I'll post pics.
Old Feb 25, 2008 | 10:55 AM
  #79
turbododgepirate
Sweet, I'll keep my eyes open for the ford and dodge wheels of the same size.
Old Feb 26, 2008 | 08:56 PM
  #80
mrbelvedere's Avatar
mrbelvedere
can we keep this thread as a sticky
