lowering kit
Old Jan 24, 2008 | 11:34 AM
300hp318's Avatar
300hp318
Default lowering kit
i want to either lower the rear so it is the same heigth as the front or lower the front and rear. where can i purchase these kits?
thanks in advance
Old Jan 24, 2008 | 01:00 PM
PushnFords's Avatar
PushnFords
Default RE: lowering kit
Usually the quickest and easiest way to lower the rear is with lowering blocks and new u-bolts. If the axle is currently on top of the leaf springs then you just put a block between them and you are lower. Most parts stores have them as well as eBay.
Derek
Old Jan 24, 2008 | 01:06 PM
300hp318's Avatar
300hp318
i have an 89 d100 soon to be what i would call a street rod. it looks like a farm truck with the back sittin up high. the springs are on top of the axle. the only problem is i would have to reweld spring mounts on the under side of the axle so that the spring would be under, but then that gets in to geometry stuff like pinion angle and i dont want to do all that.
Old Jan 24, 2008 | 06:23 PM
racer9's Avatar
racer9
Very long thread on lowering here; http://ramchargercentral.com/boards/...hp?topic=260.0 In the rear, you can use longer rear spring shackles (which can cause problems on hard cornering), straight instead of arched springs (4X4 front springs), or moving the springs to the bottom of the axle, which also involves C-notching the frame for clearance.
Old Jan 24, 2008 | 09:14 PM
2NDGOROUND's Avatar
2NDGOROUND
have you measured to see how much difference there is back and front.....?
Old Jan 25, 2008 | 12:42 PM
300hp318's Avatar
300hp318
everything they talk about or sell is for 94+ i have an 89 and cant find anyone or anything to lower this truck.i dont like the way it looks now and you dont lift a two wheel drive.
Old Jan 25, 2008 | 03:35 PM
Nofrag's Avatar
Nofrag
Look here dude http://www.truckinsuspension.com/index.php?cPath=96_98
Old Jan 28, 2008 | 09:46 PM
moparborn's Avatar
moparborn
Thats where I got my lowering parts.
Old Jan 29, 2008 | 09:42 AM
mrbelvedere's Avatar
mrbelvedere
how far does the springs lower the front end
Old Jan 29, 2008 | 11:19 PM
moparborn's Avatar
moparborn
The springs I used dropped about 2 ",then I cut one wrap off and lowered about 2" more.
