1st Gen D150 & Late Model 5.7 Hemi Swap??
Old Feb 17, 2008 | 01:41 AM
89 d150's Avatar
89 d150
Default 1st Gen D150 & Late Model 5.7 Hemi Swap??
I currently ownan '89 D-150 short boxwith a 3.9 V-6. Like everyone else, I'd like to drop it down and go the V-8 route. My idea is to install a 5.7 Hemi from a Ram/ Durango/ 300 due to the respectable amount of powerit wouldgenerate as well as the reliability factor. I may be able to secure the engine at abargain price. I also have a relative that owns a machine shop, so fabrication for mounts and suchis not out of the question.
My question is this... has anyone done this yet? If so, what am I up against? What aftermarketcomputer options do I have? What transmissons will work? Am I on crack for thinking about such a project?
Old Feb 17, 2008 | 10:32 PM
lugnuts's Avatar
lugnuts
Default RE: 1st Gen D150 & Late Model 5.7 Hemi Swap??
Pass me the pipe wudja? I've had the same thoughts. I'm no expert on the subject, but I do read alot of articles on such stuff. Mopar perfomance offers a retrofit computer setup for F.I. or carbed setups. I think around $2000 for the F.I. by the time you buy the fuel pump,lines etc.Not cheap. F.A.S.T also offers a computer, but it's no cheaper. The 3rd gen's lack of a distributor requires a computer even carbed which sux, though I did see abit of newson a replacemant timing chain cover and gear setup that will have provisions for a dist. Should be on the market soon. How cool is that? As far as the trans, M.P. has a flex plate tobolt upa smallblock 727, or an early non computer 518 O.D. Not sure if their computer set up will work with a late trans. Keisler Engineering has a manual if your pockets are deep enough. Chk out the March '08 HOT ROD mag, they're dropping one in a Challenger, might give some ideas. I've seen one in a 150 someplace but damned if I remember where. Nothing's in my price rangethough, and adapting the factory harness has been done but it's said to be a nightmare.
Old Feb 17, 2008 | 10:34 PM
moparborn's Avatar
moparborn
It is a good direction,maybe not an easy one.
it would be best if you can get motor /tranny/computer and harness.
If you can get all them,it will be alot easier.
Old Feb 17, 2008 | 11:31 PM
dragonmaster69's Avatar
dragonmaster69
Member
hey if that is too much trouble I have a rebuilt 318 you can get cheep and wont cost that much to swap things over
Old Mar 8, 2008 | 07:37 PM
89 d150's Avatar
89 d150
Thanks for the info. I thought it over for a couple of weeksand decided to go with either a 318 or 360 power plant. I'm planning on a NASCAR Craftsman Truck as if it were invented in the '70s theme (I know mine's an '89, but it's the only short box truck I own right now,plus it's much more interesting than V-8ing an S-10). I may even go Petty Blue. I'll post pics and relative info as the project progresses.
Old Mar 9, 2008 | 01:24 PM
Fnix's Avatar
Fnix
Would it be much easier to use an Older mopar block then a new Hemi block? It would probably sound more fit to the vehicle as well.
Old Jun 22, 2019 | 08:23 AM
Thomas Stubbs's Avatar
Thomas Stubbs
so dreamers that lost motivation! Well I will be the one to 3rd gen hemi swap my 81 stepside and i will be pulling asphalt off the streets👍
Old Jun 30, 2020 | 10:09 PM
Joeymoore's Avatar
Joeymoore
How is the swap going? I just brought home a 84 and I intend on the hemi swap asap. I have the engine 8 speed trans and the computer. I don't have the harness though.
Old Jul 1, 2020 | 04:18 PM
That was his last post here... and hasn't been here since.
