engine idel problem(vacuum leak)
Old Jul 10, 2008 | 12:08 AM
Loud Pedal's Avatar
Loud Pedal
The Total Package
Default engine idel problem(vacuum leak)
well......my boss has a 91 ram with the 318 and it has about 225,000 miles on it and its starting to show its inner(im gonna crap out) looks....some days the truck runs great, but others it will idel up to 30 MPH without touching the gas pedal and others it will die from not giving it enough.......so he brought it in and got it checked and a code said it was a vacuum leak near the MAF sensor....hes replaced all the lines that he could see from under teh hood and he cannot figure out what is worng.....hes wantign to get it to run decent so he can trade it on a 93 ram 4x4 with 120,000 miles less..........any ideas what could be wrong???
Old Jul 10, 2008 | 08:52 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: engine idel problem(vacuum leak)
Magnum engines don't have MAF sensors. The MAP sensor is on the back side of the throttle body. No hose going to it-just a stubby piece of rubber that connects it to the manifold.
Old Jul 10, 2008 | 02:30 PM
kurts2's Avatar
kurts2
A bad MAP would cause the engine to advance (or retard) and run poor, its a cheep fix.
Old Jul 15, 2008 | 05:59 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
welll....ill ask him and see what all he said...it was late and he was pretty well into his beer
Old Jul 16, 2008 | 01:31 AM
khooper's Avatar
khooper
Here are some other things to check for. Make sure the EGR valve is okay, check the air filter to make sure it is clean. Check the fuel pressure to make sure the pump is working okay. Check the cold advance solenoid valve and the fast idle control solenoid valve.
______________________________
Heard the news at Autopartswarehouse.com
Drive Safely and Smile Freely
Old Jul 17, 2008 | 12:01 AM
nemesis_SS's Avatar
nemesis_SS
ORIGINAL: Sixtysixdeuce
ninety ones arent magnums. At least, mine isnt. i wish it was.
Old Jul 17, 2008 | 06:22 PM
Comma's Avatar
Comma
ORIGINAL: nemesis_SS
Makes no difference then, LAs don't have them either, though most of us with LAs wish we had Magnums. Either way the MAF has been eliminated as a problem. The possibility of a vacuum leak has to be eliminated first and foremost. The MAP, EGR system and all other vacuum lines/fittings should be checked again, then the fuel delivery system. Maybe the fuel filter needs replaced.
Old Jul 17, 2008 | 06:35 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
he replaced the MAP sensor and somedays it runs great and others it dies on oyu like 4 times in an hour.......soo ill see about the fuel filter and EGR thing
Old Jul 20, 2008 | 05:45 PM
kurts2's Avatar
kurts2
You need to find the vac leak. Buy a "mighty vac"...they are good and inexpensive. With it, you can isolate the vac components.
