86 ram /6 to 360 what do i need?
Old Oct 24, 2009 | 04:46 PM
BBdart's Avatar
BBdart
Default 86 ram /6 to 360 what do i need?
Finally swapping out the slant 6 for a 360 and need to know what all i need to rob off a donor truck for the swap. I plan on using a msd 6al box for the ignition and a 727 for a tranny. I was wondering if the crossmember is the same or do i need to get a crossmember from the donor truck? Also is there anywhere to order motor mounts or do i need to get them off the donor truck too? Thanks for all the help guys
Old Oct 25, 2009 | 10:56 AM
tooltime's Avatar
tooltime
On the motor mounts i had to replace mine. I got them at www.rockauto.com for like $3.00 each,in town they were about $10.00 each. Dont forget the trans mount?
Old Oct 28, 2009 | 06:34 AM
Ironmower's Avatar
Ironmower
You should have everything you need, providing the "donor" truck is mostly complete. I'd get some new motor mounts if the donors are bad.
What are doing the swap in? Is the donor the same? Need more info, please.
Old Oct 28, 2009 | 10:07 PM
BBdart's Avatar
BBdart
I dont have a donor truck, I was planning to go to junk yards and hopefully find everything I need. As far as for motor mounts I was planning to buy new inserts but I need the actual mounts themselves for the V-8. The truck I am doing the swap in is a 1986 d100
Thanks for the input
Old Oct 29, 2009 | 03:28 PM
SEAL's Avatar
SEAL
Buying a donor truck will probably save you a lot of money rather than buying individual parts.
Old Oct 29, 2009 | 05:45 PM
BBdart's Avatar
BBdart
What exactly do I need off of the donor truck?
Old Oct 29, 2009 | 10:57 PM
lugnuts's Avatar
lugnuts
Crossmember's the same. Trans mount's the same design, but locates the engine differently fore and aft. Get any V-8 auto trans mount, the mtr mnt brackets, isolaters. Check your radiator to see if the necks are in the right spot to work with your water pump. {Not I beleive} Nothing else from the scant sicks will work, except the alternator itself, and maybe the fan.
Even a rusty $100 turd 318 donor truck would save you major time and headaches hunting brackets and do dads, and be cheaper too. I'd find one if you can.
Old Oct 31, 2009 | 02:25 PM
BBdart's Avatar
BBdart
Thanks for all the help guys.
Old Nov 1, 2009 | 07:44 PM
BBdart's Avatar
BBdart
ok so i found a parts truck. It is a 1978 model with a v-8, will the parts sill interchange to my 86' or should i try to find a newer truck?
Old Nov 1, 2009 | 10:41 PM
crazzywolfie's Avatar
crazzywolfie
what shape is the 78 in ? might be easier to use it. if it has a 50 way Bulkhead Connector it should be ok.
