Rear shackles gone bad :(
Hey all,
I have a 1987 Dodge W150 4X4 360 4BL automatic. I just went outside and noticed that the drivers side of the truck was sagging a bit more than the passenger side. I looked under the truck and found that the shackle on the DR side rear had eroded away and left the leaf spring up tight against the bottom of the bed. I know that I obviously have to replace the shackle and the bolt, but where do you find such a thing? Can I just go to Autozone and get what I need? If so, what do I ask for? Or do I have to resort to finding one in a salvage yard? Any help would be appreciated. Thanks for your time.
Just make sure it's the actual shackle and not the mounting bracket on the frame.
I had the same thing happen on my 87 and it was the rear mount that rusted away.
(leaf actually poked a hole thru the bed!) Either way you won't find it at the chain
stores, I didn't! I do still have the new OEM shackles and mounts, for both sides.
truck died before the I could fix it. Double check the mounts and let me know if you're interested.
What rusted away is the bracket that mounts to the frame. The leaf spring is slammed tight against the bottom of the bed. The other side is pretty much rusted out too. What are you asking for shackles and mounts? Just curious, not sure I can afford them, but I'm sure that I will need them. Thanks for your time!
Well, atleast my issue doesn't look quite that bad! However, the hanger that attaches to the frame does look about the same... (broken)! Is the hanger that supports the leaf spring, and that is attached to the frame called the shackle? Thanks
