91 ram diesel smokes
Old May 14, 2010 | 12:03 AM
azaware's Avatar
azaware
Default 91 ram diesel smokes
Hi
Wonder if anyone knows why when a step on it to go it smokes? When I drive it really easy or get up to speed it's fine. thanks
Old May 14, 2010 | 12:37 AM
crazzywolfie's Avatar
crazzywolfie
that is what diesels do. i don't think you can really do much about it.
Old May 14, 2010 | 07:44 AM
SEAL's Avatar
SEAL
As you accelerate the manifold vacuum drops because the cylinder vacuum rises. As this happens more oil is sucked past the rings and the valve seals that burns and then produces smoke. This happens in all internal combustion engines but shows up more with added wear and tear.
Old May 14, 2010 | 10:39 AM
crazzywolfie
diesel is an oil and that is why it smoke so much when you step on it. i know someone that runs there diesel on 50/50 of used motor and gas.
Old Jul 16, 2010 | 07:34 PM
1952M37's Avatar
1952M37
Not a smart thing to do!! No oil filter will trap the dirt from used Motor oil.
Old Jul 16, 2010 | 10:48 PM
crazzywolfie
the dirt eventually settles to the bottom of the 1000 litre totes so as long as you never drain it completely the dirt will stay there.
Old Jul 17, 2010 | 06:00 AM
charlie1935's Avatar
charlie1935
A diesel has very little if any vacuum.
That is why they don't have much deceleration when you release the throttle.
Old Jul 18, 2010 | 10:03 AM
1952M37's Avatar
1952M37
Smile
If you say so.
I do know a guy that has a third Gen that will run quarts of his waste oil to a tank of pump fuel, but he put on a FASS system and a fuel filter setup from a big rig.
Still any knowledgeable diesel mechanic will tell you that it is not a good thing to do.
Sam
Old Jul 18, 2010 | 10:11 AM
charlie1935
During the oil crisis in the late 1970's quite a few of the large trucking companys used the drained motor oil mixed into the fuel.
With the emission controls and rules now days I don't believe any do that any more.
Old Jul 18, 2010 | 10:59 AM
crazzywolfie
my friend that runs 50/50 of used motor oil and gas is a diesel mechanic and he has been for over 20 year and he has not had a problem running it.
