new to dodges 318/360
Old Aug 15, 2010 | 08:02 PM
olewhite's Avatar
olewhite
Default new to dodges 318/360
what do i need to swap from one to another... i currently have a 318 that im suspecting burns oil... if its bad im going to put a 360 in its place... are the fly wheels/ torque converters the same? thanks in advance.
Old Aug 15, 2010 | 08:17 PM
charlie1935's Avatar
charlie1935
You need matching torque converter/flywheel and vibration dampener for whichever engine you use.
Old Aug 15, 2010 | 08:21 PM
olewhite's Avatar
olewhite
so a the torque converter in my truck currently will not work on a fly wheel on a 360? i plan to buy a complete motor...
Old Aug 19, 2010 | 10:18 PM
olewhite's Avatar
olewhite
Old Aug 20, 2010 | 06:11 PM
wontacceptthis's Avatar
wontacceptthis
I believe you need a different torque converter.
Old Aug 20, 2010 | 07:09 PM
crazzywolfie's Avatar
crazzywolfie
if the 360 you are looking at has a fly wheel i think you might run into a few problems with the crank and being able to put a torque converter on it
Old Aug 20, 2010 | 10:14 PM
olewhite's Avatar
olewhite
so i need to find a 360 with a fly wheel and then find a torque converter from a truck with a 360 and hope it works with my trans?
Old Aug 21, 2010 | 12:30 AM
crazzywolfie
is your truck standard or automatic? if it is automatic it would so much easier if you found a 360 with a torque converter. if it is standard it should not make much of a difference.
Old Aug 22, 2010 | 03:34 PM
olewhite's Avatar
olewhite
it is an automatic... 3spd without overdrive...
