1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Battery is building up pressure after driving a bit. Will pop the cps off the top. Just did top end rebuild and cannot see how this would affect the battery being overcharged,if this is what is happening..... Could I have messed up reassembly of alternator wiring? Any suggestions?
the best way to test the voltage regulator is by hooking up a digital multimeter to the battery and check the voltage while it is running. that battery gauge in your truck is not a voltage gauge, it is an amperage gauge. if it is over 15volts you definitely have a problem
