Exhaust backfiring problem
We should have the carb back on tomorrow with a new filter. It should have been done the first day, but it's like pulling teeth to get a 17 year old kid to work his truck!
Once the fuel issue is fixed, we're getting the exhaust done with NASCAR style side pipes in front of the rear tires.
With the 3" drop, flat black paint, shaved emblems and baby moons on steelies, it'll be one bada** ride when it's done. I'll try to get a few pics up in my garage soon.
One more thing; What windshield wiper transmission can I use in this truck? When I got it, the bars were just laying in the cowl. I replaced the plastic grommets and the wiper motor, but the rotating arm on the motor is too long. Can I just change the arm on the motor or do I need the whole transmission? And is there any way to to put the cowl plate back on without pulling the windshield seal?
What is it doing that makes you think the arm on the motor is too long? If you used the proper motor this should not be a problem. If you remove the wiper blade arms and turn the wiper motor on and off at the switch the wiper system will park itself. After that reinstall the wiper blade arms in their parked position. I am not positive on this but I seem to remember when I replaced my grommets that if they are not put back correctly binding may result.
I use a hooked scribe to pull the bottom of the gasket up on top of the cowl during installation of the cowl.
This is for my brother's 79 D100 so we should have the right motor. My truck is the 86 short box with the charging issue. Sorry for any confusion I may have caused you.
I put the linkage together myself. It was just laying in the cowl when I got the truck but it was still in one piece. I just put it back the way it was and now the arm that attaches to the motor won't reach at all.
