Exhaust backfiring problem
#32
It's at the shop now so they should be able to test it. Do the 318 mechanical fuel pumps need to timed or just bolted on? I know some fords have a push rod to drive the pump, but didn't know if dodge was the same or not. We put a new pump on, and it didn't seem like it was pumping. I'd like to change it over to electric, but I don't know where to find a block off plate.
#33
There is no timing of the fuel pump. Try here or most good parts stores..
http://www.jcwhitney.com/jcwhitney/t...estid=21187800
#34
The fuel cell seems to be the problem. The filter is full of rust and there's about 1/4 inch of water in the tank. That'll teach me to buy a $20 used fuel cell! I called around and found out a new bladder will cost almost as much as a new cell, so we're going to order a new cell Monday and I'll try to find a wiper trans at the junkyard tomorrow. We're also going to run an inline electric pump to help out the mechanical pump.
#35
#36
The fuel cell is full of crud so we're just going to order a new one. The up side is he'll have a fuel gauge now. The down side is a new 15 gal cell with a sending unit is $235! The fuel pump is working fine. It seems it was all the crap in the cell causing the fuel loss. We drove it home with a piece of fuel line stuck in a gas can and it ran perfect. The only thing I noticed was it was banging and lurching when we went to stop. It sounds like yhe u-joints but I'm not sure.
