some advice on mods/tires
#51
1&2. I dont think you ever said, but can you tell if the front of my truck has a lift or what kind?
And earlier I said I had the EGR fixed. Because it was chocking while turning right and bumps and stuff. Well its doing it again. Its already died twice on me in the last couple days when I made a sharp right turn. What else could cause this?
#52
#54
#56
#58
Ok so I changed my spark plugs. Went well. Looked at my hubs, didnt have time to change them. Looks simple enough tho.
Did the check for the plenum issue. Didnt see any pooled up oil and i put a magnet in there and it stuck to the bottom. So the bottom isnt aluminum
#60
Hang on before you attempt that......I don't know if its that easy....I suggest you ask around this forum before pulling your front hubs apart...
You have a vacuum operated CAD (Center Axle Disconnect) that is how your truck "locks" into 4wd, not with the hubs, I am only warning you to ask first because I honestly don't know....I swapped my Dana 44 CAD front axle for a non-CAD/regular good old Dana 60 out of a 1 ton so I never had to deal with the 44's hubs on my rig.
Does anyone know if the Warn hubs are a direct swap? the Warn website makes it look like they are, but something makes me think you might need more then just the hubs....maybe its just me though.
