no charge !! 84 d-250
OK what's a good way to test the alternator to temporary make it work?
Check out that thread I sent you. It will show you how to wire up the alt without using the factory harness.
http://www.dodge-chat.com/forums/showthread.php?t=59
EDIT-- I redid the write-up on here so hopefully it will do some good.
https://dodgeforum.com/forum/2nd-gen...ml#post2590335
Well Wolfie's right. It seems they've got it set for members only, at least that's what it looks like. I'll see what I can do to get you the info, or just redo the writeup on this forum.
