1991 ram big block project
Old Oct 4, 2011 | 09:39 PM
MopAIR's Avatar
MopAIR
Default 1991 ram big block project
currently have 1991 dodge w150 just lifted for 36" tires and redid all the steering. Looking to transplant a 440 or 383 into it. I have a nv4500 out of a 2nd gen cummings any ideas for the tranny transfer case any buddy done this before?
auto with an LA 318 just wont do
Old Oct 4, 2011 | 10:32 PM
89ram150's Avatar
89ram150
As far as automatics are concerned, you can't put small block trannies behind big blocks (bell housing is too small). I'm assuming with the manual you're going to have the same problem. I believe the NV4500 is set up with the small block pattern. Maybe there's an adapter available? With enough money anything's possible. There are several 1st Gen's on here with BB's, but I think they all have 727 autos behind them.
Old Oct 4, 2011 | 11:15 PM
MopAIR's Avatar
MopAIR
Default Auto
Yeh I noticed a lot of the big blocks were automatic, i'm hoping to go with a stick.
Old Oct 5, 2011 | 08:03 AM
89ram150's Avatar
89ram150
I have a feeling all the big block manuals are going to be worth their weight in gold because all the muscle car guys want them. I'd almost bet that assuming the NV4500 you already have will bolt up to a small block, you could build a pretty stout 360, or even a 408 stroker, for what it would cost to find a big block and a 4 speed to put behind it. Just a thought.
Old Oct 5, 2011 | 11:21 AM
sls001's Avatar
sls001
http://www.jegs.com/i/Lakewood/620/15335/10002/-1
From what I've read elsewhere the Lakewood 15335 will work or you could modify a BB 435 bell-housing to work if you could find one.
With 36" tires I hope your looking for D60 axles especially if your going to a BB...
Old Oct 9, 2011 | 09:56 PM
jrock383's Avatar
jrock383
the engine mounts bracket in your truck are made for a big block they will have two sets of holes marked A/B eng if you wanna run a stick you will also have to find a manual trans crossmeber too, the auto crossmemeber wont work. I put a BB in my 87 shorty but the truck was manual already and I was able to find a BB bellhousing and trans for it. I have an aluminum 10 and a half bellhousing Im not using, so if you find a trans I got your bellhousing.
Old Oct 12, 2011 | 09:18 PM
MopAIR's Avatar
MopAIR
thanks for the link to the bell housing. Now all I need for the major parts is to select/find a transfer case and find either a 383 or 440. I found a 440 out of a rv with 34,000 miles for 400 that runs. Any input on the rv 440's?
Old Oct 12, 2011 | 09:24 PM
89ram150's Avatar
89ram150
I don't think they had more than 200hp or so, but enough torque to pull down small buildings.
Old Oct 13, 2011 | 05:57 AM
1986JEEP's Avatar
1986JEEP
The rv 440 work good putt a hemi grind cam in and work the heads and they work very well my dad had one in his race car with the set up i talked about(above) and ran mid 12s (pic of the car in my sig) .That bening said the 400 or 383 will be easer the 440 is wider and you will need a smaler break boster. I just did a 383 swap in my 84 fit like a glove.
Old Oct 13, 2011 | 07:09 PM
jrock383's Avatar
jrock383
Plus if you take the RV 440 it will have the motor mounts you need too. Your right Jeep My 383 fit like glove and Ive got 440 906 heads on mine and Ive got mine on air bags.
