spedometer issus 86 d100
well i finally got my 86 dodge d100 up an goin..it has a 727 trans 2wd
now when i took the motor/trans out it worked fine..
the spedometer gear/cabl is plug in correctly, and gear is in good shape.
now theres a 3 prong sensor on the drivers side of the trans...guess it went to reverse lights i left it unplugged...is that a speed sensor instead? lol
Good point. Was the speedo gear removed at any time? There are numbers on the speedometer pinion adapter housing and a small indicator dot at the bottom of the hole on the case that must be lined up correctly to correspond with the number of teeth on the gear being used. You must also be sure that the tabs on the the retainer clamp go into the slots in the adapter housing.
ok today i rechecked everything, i counted 32 teeth, put it on the number 32 lined up the dot an it still dont work
gear is fine, i didnt pull it out this time by accident..put a drill on the cable an the sped went up..
now there is a 38 right by the 32, then a groove..do i put it in that grove? id guess it was for a 32/38 tooth?
Trending Topics
