Rough ride, would Skyjacker solve the problem?
I have an original W250 1989 with Cummins. The suspention is very hard, and I would like to accomplish a more smooth and soft ride. The only not-oem I've found is suspention from Skyjacker. Anyone who has tried a set from this manufactorer?
I do not need lift, but Skyjacker has a one inch lift set that would do the trick, if, of course the set will provide a softer ride.
Anyone?
regards
The N.
Anyone?
regards
The N.
Thanks for reply.
There are not som many of these trucks in Norway, only 14 to be excact, so I have nothing to compare with ;-)
I'm not that good in english to speak on a phone across the atlantic, so no, I've not talked to them. And there is no emailadress either for customer support.
I hoped someone here knew enough to give me the answers I needed.
Trending Topics
I gave you an answer. It isn't cheap or easy but it will cure the stated problem. If you want a softer ride without giving up load capacity you should look into an air bag setup. A triangulated 4 link, a 4 link with hard pan bar, or a 3 link (all with air bags) will do away with the springs and give you control over the ride quality by varying the air pressure in the bags. 3/4 ton springs of any height just don't ride very well.
