S6 ran empty now it wont stay running
I have a 1985 D100 Slant6 with the 1bbl. The truck hasnt been giving me any problems until i was on the verge of running empty. I refilled all the way up added some octane booster because i was running Texaco gas and i dont trust them. Now the truck only runs with the choke on after it warms up it dies unless i put my foot in it. I changed the Fuel Filter,and made sure it was getting gas from the pump to the carb by pulling the line and bumping the key for a second. I know the truck set for awhile before i got it. Thats why i changed the water pump,timing chain,plugs wires,cap,rotor,Dist.,and coil. Could the carb go that quick after running fine the day before? Help i gotta start a great job on Tuesday and this is my only transportation.
That makes since. Do you think i should maybe try adding some more gas from a different station and with a higher octane rating?
Here in Texas its hard to find Ethanol free. Since this has happened on Sat. ive now used a half a tank. I guess it couldnt hurt to add gas unless i have to drop the tank and replace the sock. Im thinking i should have bought Hyper Pak with 4bbl Edelbrock at the swap meet and converted it to HEI lol
Trending Topics
