Burning Oil Like Crazy
Old Jun 28, 2012 | 11:50 PM
  #21
crazzywolfie's Avatar
crazzywolfie
if your plenum is not leaking then you must be leaking the oil from somewhere else like valve covers or the oil pan.
Old Jun 29, 2012 | 12:18 PM
  #22
RamKing's Avatar
RamKing
i was bruning oil too, then i started using wynn's stop leak. i have notice a difference, i used for last year on every oil change
Old Jun 29, 2012 | 03:37 PM
  #23
Birge's Avatar
Birge
Default Magnum Engine
I want to make sure, and I am pretty sure this is the magnum engine , I am almost certain the plenum gasket is blown, this is 1992 Power Ram 150 318 MFI 4x4.
I drove it for an hour an half trip last night and noticed lack of power up hills, some spark knock, and its using oil. dont know about the throtle response but it could be better. I did the spark plugs four weeks ago, it ran better, it also has a hard time starting.
Old Jun 29, 2012 | 03:41 PM
  #24
Birge's Avatar
Birge
Side view of truck 1992 Power Ram 150 318 MFI. This should be the magnum engine, if so which kit do I specify from hughes as the years don't go back to 1992 or 1993 that I see to choose from
Old Jun 29, 2012 | 03:57 PM
  #25
crazzywolfie
that looks and sounds like a magnum to me. the hughes kit would work on truck but you can get the aluminum pan on ebay and flexpro gaskets at your local parts store for cheaper than hughes. the guy that sells the pan even gives you the part number for the flex pro gasket.
http://www.ebay.ca/itm/DODGE-JEEP-AL...#ht_915wt_1154
Old Jun 29, 2012 | 04:18 PM
  #26
Birge's Avatar
Birge
for 119 dollars at hughes I get the belly pan, new intake gaskets, plenum gasket, radiator bypass hose, thermostat, new bolts, throttle body intake gasket.
I have seen the plate on ebay you talk about. 69.99 after shipping, and by the time you get all the other stuff at your FLAPS I think your right there about the same. I am pricing it out now.
Birge
Old Jun 29, 2012 | 05:00 PM
  #27
crazzywolfie
most people are not really satisfied with the the gaskets that come with the Hughes kit. i think there was a guy in the second gen section that actually received a bad gasket and had to have Hughes send him another gasket. i think by the time it is all said and done it might be close as far as prices go.
Old Jun 30, 2012 | 10:12 AM
  #28
Birge's Avatar
Birge
Default we'll see
We'll see what comes from hughes in a few days. Oddly enough I still am getting pretty good fuel mileage, I think rebuilding the transmission and the overdrive helped a lot. On my fill up today i got 17.9 MPG. I hope its right. Don't know why it wouldn't be though. I also don't get into much.
Birge
Old Jul 2, 2012 | 03:21 PM
  #29
Cameron1997's Avatar
Cameron1997
Alright got everything put back together and no more plume of doom but now my truck idles rougher than it previously did and has a little hesitation when i give it gas. Replaced the plugs with Bosch Platinum IR Fusion +4. Any ideas what it could possibly be?
Old Jul 2, 2012 | 03:23 PM
  #30
crazzywolfie
from what i have read these trucks don't like platinum spark plugs. could also check the idle air control motor on the back of the throttle body. it would have been a good idea to take it out and clean it and the throttle body when you had the intake off but most people don't. could also need a new cat and o2 sensor since the old ones are probably damaged from burning oil.
