93' d-250 trans jumping from 2nd to od
Old Oct 27, 2012 | 03:50 PM
jester7225's Avatar
jester7225
Default 93' d-250 trans jumping from 2nd to od
I bought a 93 d-250 with a few issues that im trying to resolve. the truck shifts great through from 1-2, but when it trys to shift into 3rd it seems like theres a faint (very small) binding then goes into od. even on the downshift when slowing down it seems to stay in od instead of shifting to 3rd. i've checked the TPS and at idle its at 1.4 volts , and seems to go through the voltage with the trottle fine without jumping around. i can leave od off and shifts and runs in 3rd fine. Dont know what would cause it to skip 3rd.. would apprieciate the help
Old Oct 27, 2012 | 05:44 PM
shakysnake1's Avatar
shakysnake1
whens the last time you had a fluid/filter change on the tranny?
sounds like the bands might need to be tightened
Old Oct 27, 2012 | 07:30 PM
jester7225's Avatar
jester7225
bought it from a dealer that said the trans had been gone through so should have new filters, fluid is like new. but who knows.
Old Oct 27, 2012 | 07:35 PM
jester7225's Avatar
jester7225
i adjusted the front band but checked everything else before i had to drain fluid and adjust the rear.. but after talkin to you looks like i need to tear into in. there anything else you think it might could be?
Old Oct 27, 2012 | 07:42 PM
SEAL's Avatar
SEAL
Are you positive it is totally skipping 3RD. If it is shifting into OD immediately after the 2-3 shift the problems could be:
Faulty overdrive solenoid that is not venting properly
Lower valve body malfunction
faulty wiring
faulty computer
You may find this helpful.
https://docs.google.com/file/d/0B7J1...CNb60M8P&pli=1
Old Oct 27, 2012 | 07:52 PM
jester7225's Avatar
jester7225
its hard to tell it may be shifing into third but it kind of lugs or binds up for a split sec then shifts to od. also dont downshift into third unless you get down really slow. but with od off runs and shift fine.. the od solenoid on top the tranny? and guess it could be a number of faulty wires. im new at working on these so trying to figure it all out lol
Old Oct 27, 2012 | 08:03 PM
SEAL's Avatar
SEAL
Check page 38 in the document I posted.
Old Oct 27, 2012 | 08:16 PM
jester7225's Avatar
jester7225
cool, appriciate the info buddy..
Old Oct 27, 2012 | 08:30 PM
jester7225's Avatar
jester7225
so say the valve body is faulty, would it shift perfect (1st thru 3rd) with the od off or would it effect this sequence also? BTW love your quote
Old Oct 28, 2012 | 06:08 AM
SEAL's Avatar
SEAL
It would depend on what is wrong with the valve body but yes that could happen. I would concentrate on the exterior possibilities first as most valve body problems are beyond the scope of shade tree mechanics.
