New to DF
Old Apr 26, 2013 | 11:16 PM
xXGreyGhost86Xx's Avatar
xXGreyGhost86Xx
Ok ill look into that and also i think I'm gonna see if my current rear will hold up to the new motor and tranny before buying a limited slip
Old Aug 10, 2013 | 01:35 PM
xXGreyGhost86Xx
i think instead of my orignal plan im thinking of buy a 440 crate engine and instead of the old muscle truck im going to go for a grand touring look. and now i have more questions, what transmission with work with a 440 but yet still fit in my truck? will i need different motor mounts? can i do a suspension with a 70s model charger or chanegller or like a 99 mustang? how can i change my lug nut pattern and get around my front hubs? is this even possible? which motor can i get the better perfomance out of 440 big block or 408 stroker engine? any advice im up to hear thanks.
Old Aug 11, 2013 | 10:06 AM
wontacceptthis's Avatar
wontacceptthis
You can still use a 727, but with a big block bell-housing.
You will need the motor mounts from a big block truck, as well as the oil pan.
I don't think there would be significant improvement from switching to a vintage mopar suspension setup, plus you would have to deal with torsion bars. A sn95 mustang suspension swap would probably help, but be very difficult and costly. I don't think such a swap has been done before. It begs the question: why? Our stock 2wd front suspension isn't all that bad. Make sure all the bushings, bearings, and balljoints are fresh and high quality, replace or rebuild the steering box and column, ensure a good swaybar is in place, and you should have a decent handling truck.
Rams came with a 4.5x4 and 5.5x5 bolt pattern through the years, and parts to convert to both are available. I haven't heard of anybody converting to a more compact hub design.
Old Aug 12, 2013 | 12:09 AM
xXGreyGhost86Xx
alright well i want lower my truck the right way, but nobody makes a kit. i dont want to cut the spring i dont want to remove leaf spring, i want the right way. i know on the back i can buy a shackle kit and use them inverse to lower but the front it where im stuck. ive been told if i cut the springs it can mess up my camber and may not be fixible. ive heard i can get parts from a dodge van and lower it, but i want to know the best and right way to lower my truck. im planning on sinking money into because if i build my truck my way it will be just like buying a new car but it'll be what i want how i want it.
Old Aug 12, 2013 | 12:33 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
The lower control arms and springs from a Dodge Ram Van should bolt right in. Just make sure it's a pre-92 (I think that's the right year).
Old Aug 12, 2013 | 01:05 AM
xXGreyGhost86Xx
alright cool, and those parts can come off any b series van and does it matter which size? like will the b150 lower it any lower then a b350?
Old Aug 12, 2013 | 01:31 AM
dodge dude94
Yep, any earlier B series van. Basically it has to be boxy. lol Nope. Not that I remember. I had seen a thread on ramchargercentral (I think it was there. lol) where a guy lowered his 78 D100 using B350 van parts since it's what the yard had.
Old Aug 12, 2013 | 08:59 AM
Scooter78's Avatar
Scooter78
If you are going from a 318 to a 440, in a stock d150, I think you might drop down some just from the weight. The suspensions in those were pretty soft up front. The 318 weighs (fully dressed) about 525 lbs, whereas the 440 is a solid 670 lbs. Basically, have someone that weighs 150 lbs stand on your front bumper, and that is where your truck will sit with a big block.
Old Aug 12, 2013 | 10:19 AM
xXGreyGhost86Xx
Alright, that's handles the lowering plan
Old Aug 13, 2013 | 12:27 PM
xjarhead69's Avatar
xjarhead69
Thread is right here on this forum on how to lower using B series control arms.https://dodgeforum.com/forum/1st-gen...rmation-2.html
It starts at post 15.
Dave
