rubber gas hose
Old May 22, 2013 | 10:04 PM
tooltime's Avatar
tooltime
Default rubber gas hose
I need to get one and was wondering if anyone knows what size hose I need? How hard is it to R and R ? thanks
Old May 22, 2013 | 10:07 PM
crazzywolfie's Avatar
crazzywolfie
what hose do you need to replace? i am not sure about the 88 and newer vehicles but on the carbed trucks the return line was a size smaller than the fuel supply line.
Old May 23, 2013 | 06:07 AM
tooltime's Avatar
tooltime
It is the hose or part of a hose is rubber. It is the hose going into the tank where you put gas in(nozzle) where the door is
Old May 24, 2013 | 01:04 AM
SixGun's Avatar
SixGun
The hose in question is the filler hose. The inside diameter ( ID) is 1.75". I've been to the dealer and no luck there but there are a bunch in the boneyard for next to nothing. For myself, I went to AC Delco and they replaced it with AC Delco straight coolant hose #31009. Probably won't last as long but who knows. I've seen them on Rockauto in shorter lengths for less than $10 but I went to AC Delco and it was way pricier at $40 but I did both vehicles with some to spare for a third.
Old May 24, 2013 | 06:32 AM
tooltime's Avatar
tooltime
Does it matter how much gas is in the tank
Old May 24, 2013 | 09:09 AM
charlie1935's Avatar
charlie1935
I need to replace mine on the 87 also.
NAPA has it but I haven't
asked any where else yet.
Old May 24, 2013 | 10:54 AM
crazzywolfie
should not make a difference. you don't need to drop the tank to replace that rubber hose.
Old May 25, 2013 | 01:11 AM
SixGun's Avatar
SixGun
Yep, it just connects the metal filler tube attached to the gas cap to the gas tank metal filler tube. If you're worried just make sure it isn't full. Maybe 3/4 tank is more than low enough. Just don't drop the tube into the tank. LOL
