w150 finally needs an engine
Old Jun 8, 2014 | 03:53 PM
Comrade General's Avatar
Comrade General
Default w150 finally needs an engine
After 275k miles the 318 is about to go. The crankshaft end play has gotten bad enough to were the flywheel is hitting something and it makes a bad metallic clicking.
As much as Id like to do a 360 or cummins swap, Im leaning towards keeping it simple with another 318. Its a 92 so a magnum, which means any magnum 318 should be fine to fit, right?
Old Jun 13, 2014 | 12:32 AM
Comrade General
just picked up a reman 318 magnum long block
Old Jun 13, 2014 | 06:45 AM
RDuck's Avatar
RDuck
Originally Posted by Comrade General
just pickedd up a reman 318 magnum long block
Wouldn't a 360 have been a direct bolt in?
Old Jun 13, 2014 | 05:26 PM
1996Ram318's Avatar
1996Ram318
Someone may correct me, but as I recall, the 360 has a different torque converter and left side motor mount.
Old Jun 16, 2014 | 12:12 AM
Comrade General
The 360 is a simple enough swap with minor differences. Im not sure about the mounts, I believe they are the same. As far as the torque convertor, one is externally balanced and the other is internally balanced. I cant remember which is which. But the main reason Im not doing a 360 is because of the fuel injection, all that has to be changed and that starts getting expensive. Im keeping this as cheap as I can since I already have my go-fast truck (my cummins)
Old Jun 18, 2014 | 09:20 AM
Cmckinney99's Avatar
Cmckinney99
You can bolt a 360 in with washers on the driver side and all you have to do is pull one out of a Durango and it'll work perfect
Old Jun 18, 2014 | 02:22 PM
RDuck's Avatar
RDuck
I dont believe he's talking Magnums here.
W150 would be an LA engine.
Old Jun 19, 2014 | 05:57 PM
Comrade General
its a magnum. 92 was the first year for the 318 magnum, 93 for the 360 magnum
Old Jun 20, 2014 | 06:50 AM
RDuck's Avatar
RDuck
See. I wasn't sure. Lol.
