hi I'm billy having issue's with 94 1500 ram 4*4 5.2 liter
1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hi everyone and thanks for having me. Well i bought the truck 3 months ago a powerhouse no problems i go over railroad tracks and boom die's out. Im getting pressure from fuel pump great spark so im gonna replace cranksensor tomm/ I had it running for 5 minutes yesterday and when i hit the gas it died and went right back to cranking but no starting. I took a old timers advive and sprayd wd 40 all over distribiter coil and wires for plugs and this is what made it start and idle for 5 minutes if anyone knows another issue it cold be besides the crank sensor let me know please thanks god bless
I would suspect a bad connection over a bad sensor. Wiggle the wires around the pcm and see if you can replicate it.
I will buy the wire cleaner stuff that you spray on then wipe gunk off i have a lot of gunk on all kinds of sensor wires and chaging the crankjshaft sensor is a pain in rear end my arm are to b ig so cant get down to the old one to get the two screws off gonna have to call one of my skinny friend lol with bones for arms ty very much
It's behind the passenger head, Two bolts hold it in. You usually can get to them from the top of the motor. But sometime you have to go underneath to reach them.
