1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
i just bought this truck its a 1979 dodge 300 club cab i dont know what transmission it has but it is an automatic it has a 360 motor the transmission went out yesterday in it it shifts to reverse just fine but drive threw d1 it makes noises did a fluid and filter change today i think the transmission is a 727 but not sure also need help with the wiring diagrams
Ok the transmission is a 727 I do have a 904 will it work till I get the other one rebuilt?? But is the tail housing too long and mine is a bolt on drive shaft
They are very similar, The 904 is more suited for lower hp rating as the 6 would be. You could use it temporarily if it will work with your truck. There where some differences in tail housings/slip yokes etc...
Thanks for all the help I learned a bunch from.research and yall. But will a 727 with a longer tail housing that's mounted up to a 318 bolt up to a 360 both trucks are the same year
