Steering Stop lubricants
85 D-250 (318, NP-435, Dana 60, 87 ferd 16" 8 lug rims)
I'm slowly getting this rig fixed up but I have an issue that I've had on both my previous D 150's (a 79 and an 80) with steering stop noise when turning a full lock to the right.
I was wondering if anyone knew of a source for the correct wax based lube for the stops?
Or do I just grind my dentures together so they're louder than the noise from the stops??
Budd
(Whose starting to appreciate the "trunk space" utility beds have . . . . .)
Budd
I've tried that several times but my town has streets reminiscent of city streets in many small eastern towns ... narrow with curbside parking and the chassis grease rubs off in a short time.
There used to be a weather resistant wax based lube for them but I've not seen any for years in the parts stores.
Thanks for the reply.
Budd
Budd
<VBG>
Budd
That's what I was thinking to.
Trending Topics
Gentlemen,
The noise is a rough, loud grinding noise that occurs when making full lock right turns in reverse or, at a slightly lower volume, low speed forward directions of travel as the suspension on the passenger side flexes to accommodate variances in the surface of the ground/road.
I have, in the past and in better health, crawled under the vehicles while stopped in positions that have resulted in the noises and observed the steering stops on the right hand spindles in contact with the rearward pointing stub on strut rod as well as checking those contact points after returning the steering to the straight ahead position and seeing bare metal surfaces from the rubbing.
It is not the tire rubbing the wheel opening as I run stock width tires on my vehicles with stock offset rims, though the D250 does have Ford 16" X 6" rims which may have a different offset than the OEM 16.5" X 6" rims.
The noise does not happen when turning to the left and the front suspension and steering linkage was rebuilt less than 2000 miles ago and aligned at a local tire shop with an excellent reputation for their work.
I apologize for thinking I had explained this problem in my OP as I apparently failed to do so.
Budd
Budd
I see you didn't see the smiley or the VBG in the reply, but your reply gave me the impression you didn't think I know diddly about vehicles and I wanted to correct that.
My apologies.
Budd
Interesting that only the right stop hits and not the left. This all occurred after the suspension work and alignment?
just thinking out loud here: the steering box was centered at it high point when the toe was set. You have equal steering turning in both directions? Is the steering box capable of moving to the left far enough to hit the left stop?
I think you are hearing the belt slip on the ps pump. it shouldn't make any noise when you hit the stop unless it's something else.
