87 Ram 150 Engine Swap
Old Dec 14, 2017 | 12:21 PM
corvetteram's Avatar
corvetteram
Default 87 Ram 150 Engine Swap
Dear forum users,
What would be a good engine, to swap into an 87 Ram 150 4x4 manual? I want to keep my truck a manual, have alot of power, be modern, and be reliable. Any good ideas? Thank you!
Old Dec 14, 2017 | 12:26 PM
What motor is in it now?
Old Dec 14, 2017 | 02:10 PM
crazzywolfie's Avatar
crazzywolfie
depends one what you mean by modern or reliable. i don't think there is any easy or cheap solution if you want to keep the standard transmission. you can stick fuel injection on a old engine and it should make more driveable if that is what you want. it is really hard to make something more reliable. a carb is just as reliable as fuel injections but fuel injection can sometimes be a pain to fix or trouble shoot if you start having issues with it. carbs are simple but not as driveable as fuel injection especially when it gets colder out.
Old Dec 14, 2017 | 06:27 PM
Sno/Commander's Avatar
Sno/Commander
Originally Posted by corvetteram
Dear forum users,
I would say get a V10 from a roached out plow or dump truck and hold on!!🤠
Old Dec 15, 2017 | 07:03 PM
Moparite's Avatar
Moparite
It's probably a LA 318. Magnum swap? It probably would be the easiest.
http://www.magnumswap.com/first-steps/
Old Dec 18, 2017 | 09:41 PM
silvermopar's Avatar
silvermopar
'87 still had a carburetor, I'd keep it simple with a create motor and keep it carburetor controlled, modern efi is a real pita to work on in my book, unless you understand electronics and have expensive scanners.
Old Dec 21, 2017 | 08:18 AM
93 ragtop's Avatar
93 ragtop
I have a 87 dakota and plan to do the same thing. (put in a more powerful motor)
To me, its a no brainer. Go with a magnum over the LA. Makes more power and the bottom end holds up better.
You can use a edelbrock 7577 intake. (converts magnum to a carb motor) and a small 4bbl carb.
Use a HEI ignition .
In line electric fuel pump.
IMO this is the easiest way to do it.
Assuming you have a 318 now, and if you use a 5.2 magnum, you can reuse your existing flywheel and clutch.
If you have a 360 or want to use a 5.9 you will need a different flywheel
