owners manual disinformation.
Old Sep 21, 2020 | 07:32 PM
Xombi's Avatar
Xombi
Default owners manual disinformation.
I was using my owners manual to help with fuse location. After checking the back of the fuse panel I found it incorrectly labeled. 5 amp fuses running headlights and blank spaces needing fuses.
Trying to figure out why i am getting less than half a volt to run the instrument illumination lights.
the open fuse place on the right labeled 14 by the manual needs a fuse.
Old Sep 22, 2020 | 06:34 AM
Moparite's Avatar
Moparite
Not according to what you posted, The "4" looks to be missing from the top one. 14-15 empty. You may want to post the vehicle info!
Old Sep 22, 2020 | 09:07 AM
Xombi's Avatar
Xombi
Default 14 and 15 are listed as spare spaces in a 1987 Ram 150
. It's a federal truck.Truck is a 1987 ram 150 5.2 LB. 14 and 15 are listed as spare spaces in my 1987 ram 150 manual. There are female spade connectors in 14. Yes the one was rubbed of by the contact cleaner in the 14 position
Old Sep 22, 2020 | 09:12 AM
Xombi's Avatar
Xombi
Anyone know if the Haynes Manuals have schematics for the 1987 model?
Old Sep 22, 2020 | 10:15 AM
Factory service manuals are available on EBay.....
Old Sep 22, 2020 | 10:26 AM
Xombi's Avatar
Xombi
I ordered a FSM almost five weeks ago, it shipped, and it is lost in the postal quagmire. I had the same problem earlier with a shirt that was to be a b-day present, 5 weeks to get from Denver to Baltimore. The tracking number stalled for ten days at a postal hub less than five miles from my home. Do you know if a Chilton will have needed complete schematics for my 1987 Ram 150? I tracked one down at an Advanced Auto.
Old Sep 22, 2020 | 10:28 AM
Chilton and Haynes manuals only have generic wiring diagrams. I don't think I have ever seen one that actually reflected the reality of the wiring on anything newer than about 1979.......
Old Sep 22, 2020 | 10:53 AM
ol' grouch's Avatar
ol' grouch
I ordered some audio books on a thumb drive. It was supposed to take 5-7 days. It went past my house at least twice. Spent a week in Honolulu, went to Alaska, back to Honolulu, spent a while in California. All in all, it took 5 weeks to travel 200 miles. I have to wonder when my packages travel more than I do and more interesting places.
Old Sep 22, 2020 | 10:35 PM
crazzywolfie's Avatar
crazzywolfie
hahaha hey you are you getting too old to troubleshoot? 8 posts in and no one has asked the most important question. have you tried turning the headlight switch with them on? that may be why you are only seeing partial voltage. the more you rotate it the more power you should get to light up the gauges. rotate it till just before it clicks should be full brightness. if that doesn't work you may need a new headlight switch. the click should turn on the cab light just like opening the door.
Old Sep 23, 2020 | 12:33 AM
Xombi's Avatar
Xombi
Default solutions
I did put a volt meter on headlight switch rheostat brightness, and ohmed it as well. Without a correct schematic you don't know where you are coming from and where you are going.
The fuse panels are a mystery.
