87 d100 lift
Old Dec 21, 2020 | 11:17 PM
nlamke's Avatar
nlamke
Default 87 d100 lift
So I have a 1987 d100 I want to put around a 4” lift on it, Any cheaper reliable option y’all know of
Old Dec 22, 2020 | 07:01 AM
Isn't that leaf springs at all four corners? It really doesn't get any easier than that......
Old Dec 22, 2020 | 07:05 AM
nlamke's Avatar
nlamke
its coils in the front leaf in the back but I heard some don’t work on d100/150s but other ones do and the people saying that don’t say were to get a kit that fits a d100
Old Dec 22, 2020 | 07:12 AM
Ah. Ok. Yeah, that makes things a bit more expensive. The lift gets more complicated, thus, more expensive..... To get 4" though, gonna have to spend some money.....
Old Dec 22, 2020 | 04:30 PM
crazzywolfie's Avatar
crazzywolfie
sixgun
Old Dec 28, 2020 | 10:28 AM
1983D150's Avatar
1983D150
I've got the same truck body as you have. Perhaps the bed length is different. Mine's a long bed but for all that
matters: that does not make a difference in lifting. (don't know if your shifting manual / floor...mine is!)
Gave my truck a 3.5" lift and it's not expensive to pull it off.
Most of the work is "hard and manual". Hope this helps:
What I needed to convert:
- Get lifting blocks between the frame and cabin / bed.
- Replacing your brakelines as they won't fit to the master cylinder no more
- Moving your radiator up and getting longer hoses
- For me no changes on the Fuel side cause I converted to LPG gas
- Adapting the angle from your steering collumn (as the angle will change to the housing)
- Extending your shifter if you drive manual so you can grab the **** without knocking your head on the dashboard)
- Lowering your trailer hitch if you've got one including wires
- I forgot if I changed something with the clutch system (I own the truck for over 20 years you see)
- (Manual) for floor base of the shifter (plaatic thing with the chrome ring) blocks shifting so needs extension of a short throw shifter)
With a 2WD, it is far more work as indicated in the post here than with a 4WD.
But....a 2WD drives nicer allover so when I am off road than I decided to rev up by 70%
I lifted mine because it looks good and I had more space to fit 3 pcs of LPG gas tanks under it. (one blow the cab and two behind the
rear axle to add some weight as well.
Was great fun to do and looks GOOD...keeps you busy for two weekends
Old Dec 28, 2020 | 01:34 PM
volaredon's Avatar
volaredon
Sounds like you did a body lift instead of a suspension lift
Old Dec 28, 2020 | 02:41 PM
1983D150's Avatar
1983D150
Correct bodylift. I didn't catch it was for a suspension lift.
I also don't know what would be the best to pull that off, but since it's a 2WD the ground clearance would not be the target but the achievable height.
For sake of stability I'd say a combination of body and suspension lift would keep the costs lower than full suspension lift. But that's my assumption
