1987 dodge d100 that jumped time
Old Jan 22, 2022 | 11:12 PM
Richard myers's Avatar
Richard myers
Default 1987 dodge d100 that jumped time
I have a 1987 dodge d100 5.2L. The original cam sprocket, witch had the plastic coating on it broke all apart as I was on my why to work. Been trying to fix it but not sure how to set the time back in time I have done timing work on other vehicles similar to this set up but never dealt with this problem of jumping time. Been told things by a few people to try and tried but no luck. Looking for any advice please help
Old Jan 23, 2022 | 07:43 AM
Moparite's Avatar
Moparite
You need to replace the timing chain and gears. When you get the new set there will be marks on both gears that you line up and that's how you set it. If the plastic broke off the gears you need to remove the pan also because the plastic finds ti's way into the pick up screen.
Old Jan 23, 2022 | 09:30 AM
Richard myers
I have done so.. new timing set, cleaned the pan and screen. Lined the marks up. Cranks over but won't start back up. I was going down the highway doing 60 when this happened
Old Jan 23, 2022 | 10:19 AM
Might just be 180 out. With the dots on the cam and crank gear lined up, cylinder 6 is actually in firing position, not 1.
Moving this to First Gen Ram section for ya.
Old Jan 23, 2022 | 11:38 AM
ol' grouch's Avatar
ol' grouch
Pull the #1 spark plug out and rotate the engine by hand. I usually will use a wooden dowel rod but you can use a screwdriver to watch the piston. When it gets to TDC (ttop dead center) check your rotor location. Chrysler engines use a flat tab on the bottom of the distributor shaft. Unlike Furds for instance where a gear rotates to rotor when you lower it into the block, you can pull the distributor and rotate it half a turn (180 degrees like HeyYou said). This will get you close and should get it running. Then you can time it. That nylon coating on the gears made the cars run really quiet when new but with age, it comes apart.
Old Feb 9, 2022 | 06:34 PM
volaredon's Avatar
volaredon
if the timing chain did jump, you may have some bent valves. meaning heads need to come off to replace them, in other words a "valve job".
Old Feb 9, 2022 | 09:11 PM
ol' grouch's Avatar
ol' grouch
The valve should be okay. The 318 isn't an interference engine.
Old Feb 10, 2022 | 07:03 AM
volaredon's Avatar
volaredon
Not if it only jumps a tooth or 2 but I've seen it happen on a 360 before.
