Electronic Fuel Injected Carb?
Old Apr 9, 2022 | 12:00 AM
chapol's Avatar
chapol
Default Electronic Fuel Injected Carb?
Some one mentioned to me that there are now electronic fuel injector style carbs to swap out a traditional carb. Is there already a thread on this subject or does anyone know anything about that? I can't seem to find anything in the forum.
I'm looking to swap a new motor in and curious about what other upgrades i can do at the same time. As long as they are inexpensive, relatively.
Thanks!
Old Apr 9, 2022 | 08:41 AM
They are throttle body injection systems. Something that the manufacturers have been doing for quite a while now, though most of them have moved to port injection, as it is more efficient. Holley makes several standalone systems, along with a few others. For the more popular motors, (chevy small block....) there are a fair few companies that make retrofit port injected systems as well.
Old Apr 10, 2022 | 05:14 PM
crazzywolfie's Avatar
crazzywolfie
the biggest pain for going with TBI is the fuel system. if you do go with TBI may be worth trying to find a 91-93 fuel injection tank or you will likely have to spend lots of money on a fuel pump assembly. i would avoid going with inline fuel pump. they don't seem very reliable. in tank is generally very reliable but the hole on a 87 and older tank is very small and would be hard to get a fuel pump in and keep it in 1 place and avoid fuel starvation.
Old Apr 12, 2022 | 02:39 PM
chapol's Avatar
chapol
Thanks for the info!
