1992 ram 5.2 short bed, leaky gas tank
Old Nov 14, 2022 | 12:52 PM
mischiefnmopars's Avatar
mischiefnmopars
Default 1992 ram 5.2 short bed, leaky gas tank
So recently I have discovered my fuel tank is cracked towards the back strap...they don't make any reproduction tanks and I'm having a hell of a time finding a good tank in scrap yards...anyone have any suggestions? Other factory tanks that have been used, fuel cells....what are folks doing about this?
Old Nov 14, 2022 | 01:09 PM
Steel or plastic?
Old Nov 14, 2022 | 02:02 PM
crazzywolfie's Avatar
crazzywolfie
could try getting it plastic welded. petty sure they only made the tanks for 3 years 91-93 so they are not very common. if i was going to do something i would go for a fuel cell mounted between the frame rails at the back.
Old Nov 14, 2022 | 04:30 PM
mischiefnmopars
Steel or plastic?
plastic...22 gallon
Old Nov 14, 2022 | 07:10 PM
Plastic can be repaired. Several methods for it. So, if you can't find another one, just fix what ya got.
Old Nov 14, 2022 | 07:54 PM
crazzywolfie
https://www.ramchargercentral.com/th...l-tank.333604/
Old Nov 18, 2022 | 11:39 AM
69_XS29L's Avatar
69_XS29L
Side story, partially relevant. Old mechanic I worked for would braze steel fuel tanks. Run a hose from idling vehicle, purge the vapors, leave running. Exhaust permitted no combustion, tank brazed, problem solved. Life was different in the 50-60's/Montana. I never saw it, but his son ran the shop, said 'twas true.
Can only imagine what the internet parrots and screamers would pontificate about this. Old guys got it done.
