Need help with 1991 D150 with 318
Old Jul 2, 2023 | 03:16 PM
  #21
ol' grouch's Avatar
ol' grouch
Originally Posted by Joner's Motors
Wouldn't the computer throw a code if that happened?
No. On OBD II, especially newer ones, it would because you have crank position, cam position and even maybe flatulence sensors. You're running OBD I. While it was advanced for the time, it's closer to what came in your car than an OBD II system. Add fuel injection and a roller cam to the 270 that came in your car and you'd have what you've got now.
Don't get me wrong, I like OBD II, but for purely mechanical issues, a vacuum gauge, volt/ohm meter and wooden stick will find and solve a lot of problems on OBD I. Personally, I would have gone through that engine on an engine stand before I dropped it in. However, that's just me. Do a timing chain and add a high volume oil pump to compensate for worn bearings. If you have slop in the timing chain, it's fairly easy to do in the car.
Old Jul 2, 2023 | 03:21 PM
  #22
crazzywolfie's Avatar
crazzywolfie
if it truely is a 91 computer it is only firing injector 1 and 2. definitely seems like a fuel related issue if it will fire with gas in the intake.
Old Jul 2, 2023 | 03:28 PM
  #23
Joner's Motors's Avatar
Joner's Motors
I'll do what you said and check the timing Chain, but I feel like it wouldn't run as well as it does a jumped chain.
Old Jul 2, 2023 | 03:30 PM
  #24
Joner's Motors
so the 91 computer only fires injector 1 and 2, and 92 and above fires all of the injectors?
Old Jul 2, 2023 | 04:03 PM
  #25
If cam/crank signals were "too wrong", the PCM might toss a code, but, the PCM has no way to know which cylinder is next in firing position, it only really cares about which injector is next. And it only gets a vague notion on that...
However, if the OP has a 91 computer in there, it will NEVER run that engine. The programming is so wrong, it's almost funny. First thing that needs to happen is the correct PCM needs to be installed.
  #26
crazzywolfie
here is the pinout for a 91 computer
and here is the pinout for a 92/93
Old Jul 2, 2023 | 04:46 PM
  #27
Joner's Motors
I guess I'm buying a 92 computer. Hopefully that fixes it.
Old Jul 2, 2023 | 07:59 PM
  #28
ol' grouch's Avatar
ol' grouch
I've seen jumped chains keep an engine from running period to running, but without power. I had a '54 Coronet with the 241 Hemi that jumped time and while it ran, I barely got over a hill on the way home. A new timing set and it ran with modern traffic once I put later wheels with radial tires on it. It ran 80 mph so your car with a more modern engine ought to haul the mail just fine.
By the way, when you get it running, put radial tires on it with later model wheel covers. The 50's covers won't stay on radial tires. The third time I had to chase down factory wheel covers, I put newer ones on it. I had completely rebuilt my front end but it still followed every crack and rut in the road. Radial tires cured that and it was actually fun to drive.
Old Jul 3, 2023 | 08:01 AM
  #29
Moparite's Avatar
Moparite
Do you still have the original pcm? It should have a # on it. That is what you need to get. I'm surprised it ran on 2 cylinders!
Old Jul 3, 2023 | 09:47 AM
  #30
ol' grouch's Avatar
ol' grouch
I'm wondering what engine we are talking about here. The engine in the video is definitely a Magnum. Those came out in the '92 model year. I remember because I tried to buy one but it sold before I could get to the dealer. The 1991 was the last of the LA version with roller cam and TBI.
I'd still check the timing chain due to the miles. However, a lot of my advice was for a pre-magnum power plant.
