1992 d150 318
Old Sep 6, 2023 | 09:29 AM
92 d150driverman's Avatar
92 d150driverman
Default 1992 d150 318
Uhh i want to lift my 92 d150 2wd and idk where to start and i am kind of on a budget so can someone please help me what do i need
Old Sep 6, 2023 | 09:46 AM
How much lift are you looking for?
Old Sep 6, 2023 | 10:38 AM
Moparite's Avatar
Moparite
I'll never understand this!
Old Sep 6, 2023 | 11:40 AM
92 d150driverman
im looking for anywhere from 2-4 inches of lift but i dont like the way body lifts look
Old Sep 6, 2023 | 06:11 PM
Coil springs in front? Could put blocks in the rear, those are likely still available, don't know if anyone makes spring spacers for the front or not.....
Old Sep 7, 2023 | 05:21 AM
Juggernautxtr's Avatar
Juggernautxtr
i got a long bed D150 the only thing i found for these is a 1.5" lvling kit. all kinds of blocks for the rear,body lift kits. nothing really for the front. disappointing kinda but kinda not as old as these trucks are.
drop kits galore and sure as heck don't wanna drop the girl she sits low as it is.
Old Sep 7, 2023 | 09:24 AM
Moparite's Avatar
Moparite
Looks to be the standard height for 2WD in the pic.There is not much that can be done with the control arm suspension as you found out. They do make lift spindles but not for your year.
Old Sep 8, 2023 | 01:36 PM
u2slow's Avatar
u2slow
You can probably get an inch on the front suspension with a poly coil spring spacer, or heavier duty coils. Do a 1" block on the rear. Do another inch of body lift (not outwardly noticable).
Also, if its about fitting a bigger tire... 33" already fits on the rear, and you dont really need bigger on the front.
Old Sep 9, 2023 | 08:40 AM
Moparite's Avatar
Moparite
Or buy a 4X4.
