Front Brakes
Old Nov 29, 2024 | 01:02 PM
I get:
RAYBESTOS MGD269MH
CENTRIC 30001230
ACDELCO 17D269M
WAGNER ZX269
This is from Rock Auto.
Old Nov 29, 2024 | 02:41 PM
Ram1990's Avatar
Ram1990
The Centric pads, one lookes to be thinner than the other.
I wonder why when I talked with Centric why they did not recomend the Centric pad?
Thank you
Old Nov 30, 2024 | 06:42 AM
Moparite's Avatar
Moparite
You said "Orginal Rotors" meaning they where on it when you got it or original Chrysler rotors? From what seen on ra they have this listed...
Front; Chrysler Rear Axle
Front; Dana 60; 5,000, 5,800 lb rear Axle
Front; Dana 60; 6,200 lb Rear Axle
What do you have? There are different versions of the 2500. The rotor is thinner on the lighter versions. It's possible somebody put on the wrong rotor.
Old Nov 30, 2024 | 12:26 PM
Ram1990's Avatar
Ram1990
I purchased the truck new, it is the 8510# GVW package, with the Cummins Diesel.
The rotors are orginal, with 8 lug nuts, 12" in dia and are about 11/8" thick, the rear drums are 12".
I have all the orginal paper work, nothing about rear axle.
Thank you for your reply
Old Nov 30, 2024 | 03:10 PM
u2slow's Avatar
u2slow
The light and heavy rotor are the same thickness on the 2wd. The difference is one comes off the hub, and the other doesn't. Can't put the wrong one on because the bearings are different sizes.
Old Nov 30, 2024 | 04:22 PM
Ram1990's Avatar
Ram1990
Are the light and heavy both 8 bolt?
Thank you
Old Nov 30, 2024 | 04:59 PM
u2slow's Avatar
u2slow
Yes.
3500# suspension is the light one. Shares bearings with the 5-lug. Hub/rotor is a single unit.
3800-4000# is the heavy. Comes as SRW or dually. Same rotor, but hubs are different. All cummins trucks have the heavy spec.
