1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
My 93 dodge has always started but one weekend I went to start it and it just cranked that’s it. I changed out the distributor pickup, the rotor and cap. That wasn’t the problem. I checked the ignition coil which was good but I found out the wire going to it is only getting 5 volts. I have no idea what could be the problem and wondered if anyone had any advice. It has the 5.2L 318 EFI.
The battery voltage is at 12.6 and the fuel pump does prime. I do get a very very weak spark not enough to start the truck though. The engine flashes so many codes because of the old owner but I’ve had it running properly for over a year now.
