2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
P0700 Error
Old Jan 24, 2014 | 09:05 PM
blckninja's Avatar
blckninja
Default P0700 Error
I know that with a P0700 error, the TCM has an error code I need to retrieve. My question is: Is there a tool where I can get the error code from the TCM or do I need to take it to mechanic to retrieve the codes?
Old Jan 30, 2014 | 10:57 PM
blckninja's Avatar
blckninja
Can nobody seriously help with this simple question? I haven't been able to find the answer anywhere, would be nice to get some help.
Old Mar 17, 2014 | 12:53 PM
guapoman2000's Avatar
guapoman2000
I do realize that this thread / post is rather dated (several months), however, if it is still an issue and to answer your question then, please visit...
http://www.obd-codes.com/p0700
Old Mar 20, 2014 | 11:10 AM
blckninja's Avatar
blckninja
Thanks for the reply, and the link, but I already know what the error is, and what I need to do, the link didn't answer my question at all.
Old Mar 20, 2014 | 12:19 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Sorry we couldn't serve you better and in a more timely fashion. I guess you'll be wanting a refund??
Old Mar 20, 2014 | 03:29 PM
master tech's Avatar
master tech
Site Moderator & Tech
When using a scanner to check engine codes and the P0700 code comes up, then you need to scan the transmission side of the pcm to find out what are the real transmission codes. The P0700 is to let you know that there maybe a problem with the controller or the transmission. Without all the information we maybe just guessing at your problem. Just to add this, When you are looking for answers and it been more than two days without a response. Ask a moderator, anyone of us can help you find the person to ask.
Old Mar 25, 2014 | 01:08 PM
blckninja's Avatar
blckninja
Are you too afraid to live up to the fact that you violated the rules that you are supposed to enforce on this forum that you decided to delete my other post? Or did someone else delete it after you whined and complained to them that i'm being a big bully to you?
Old Mar 26, 2014 | 12:22 AM
master tech
No rules were violated. And there was no whining either. Did you find out what your transmission codes were?
