2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Hard brake pedal and discharge noise.
Old Jul 16, 2019 | 05:08 AM
Adam Shellard's Avatar
Adam Shellard
Question Hard brake pedal and discharge noise.
Hi all,
Last night on my drive home, my 2008 Avenger went into limp mode. After further discovery, it needed more oil. I've added more oil to the engine but the car is still in limp mode and the oil warning light is still present. While limping it back home, my brakes failed on me. I have a hard brake pedal which only seems to get lighter when heavy acceleration. However, anything between 2000-2500rpm, there's a sudden "pop" and hissing noise. Just like a dump valve has gone off. This still gives me a hard pedal and next to none braking.
Has anybody got any ideas or know of a post where a similar scenario had happened.
As a newbie here, I'd thought I'll add a picture of the car in question. So here she is:
Dodge Avenger 2008.
Thank you for your time, any help is appreciated,
Adam Shellard.
Old Jul 16, 2019 | 11:04 AM
Get it scanned for codes for starters.
Old Jul 24, 2019 | 02:02 PM
Adam Shellard
Okay, after scanning for codes, the P0401 Exhaust gas recirculation flow insufficient detected.
After removing and replacing the EGR valve, the problem still
lays.
Now starting to look towards a new oil pump. And maybe a new turbo...
Old Aug 17, 2019 | 12:23 AM
lxman1's Avatar
lxman1
Site Moderator
Turbo? Is it a diesel engine?
