My wishlist is starting to get out of hand...
pipe dream or not, it will happen, even if i have to drive the dak into the ground to make the money to get it.. this dak will be my point vehicle in my transportation business venture..
side note
i mean theres absolutely no real point to it, but i would love to see a set of duallys on a dak!!!!
side note
side note
side note
Plus you'll need an axle which reads off the third member for the speed sensor, which I'm not sure how many exist as a dually axle.
What has been done for 6x6's, a ford 9 or GM Corp 14 bolt with a gear-over box to pass the driveshaft to the third axle, which was the stocker.
Since you've converted yours to a cab/chassis, you have very few restrictions to what you can do.
the first one looks funky, but explains how i saw a dakota built as a camper in a town close to me.. but the third pic, and the yellow dak look freaking nice.. the 2nd pic, looks like they put a dually hub on a standard length axle... look at the inside wheel, its perfectly inline with the front wheel..
most duallys i see, the center line of the 2 rears is inline with the front axle
Dually axles are free-floaters so that if the axle breaks, you don't lose the tireset. On a semi-float, the wheels bolt directly to the axle, which is supported by an axle bearing. On a dually, the axle is a spindle, and the hub slides over it like the front axle, then the axle shaft slides in from the outside and attaches to the hub.
Racecars faster than some number I forget have to be full-float.
i like that, and im saying that based off the fact, u do racing, and with that precision specs have to be DEAD on.. wich explains all the math.. maybe you can provide me some insight, im having issues with the exhaust manifold studs.. i got a topic on the issue on here, should still be on page one
EDIT: https://dodgeforum.com/forum/2nd-gen...old-snafu.html
it wasnt on the front page.. haha heres the link
We moved the motor forward and front axle line backwards over winter....didn't quite realize how close some things are. Stepping up from 850 HP to 1000 HP and wanted to get our weight center further forward. The scales will show how much moving the motor forward 1/4" and axle-line backward 1/8" changed.
We made a 1000' pass in the fall, it shut down at the turnoff from running dry. It probably wouldn't make it to 1/4 mile. The tank is only 3 gals.
