My wishlist is starting to get out of hand...
In order of precedence:
1. Baseline Dyno Run ($50-75)
2. Methanol Injection ($268):
- a. Pump - $140
- b. Nozzle - $27
- c. Tubing - $30
- d. Tank - $11
- e. Blockoff Solenoid - $60
3. Custom Hemifever All-Out Tune (already paid for)
4. Powertrax No-Slip Locker - $490
5. MSD ignition ($300):
- a. MSD 6A Ignition Box - $175
- b. HVC Coil - $125
6. Postline Dyno Run ($50-75)
7. Slicks and Wheels ($497):
- a. M/T 3019 slicks - $391
- b. Cragar 15x8's - $106
Total: $1,655...after variances, shipping, ect, figure it'll round off to around $1,800.
I'm going to see if I can score a set of stock 15x7's any cheaper, but the cragars are a cheap fallback.
If it lets me have the license plate "8SEC V6NA" then it's worth it
Goal is an 8.99 1/8 mile so I can run the electronics class. Ideally would be 8.70's for some breathing room on the class cutoff.
I have 1.7 harland rockers, clutch fan delete/Lincoln fan mod, SCT can tune, 4.10's, and 265/70-16 tires.
Bone stock (3.55's) I was in the 12.40's with 2.8x sixty's. Now I'm in the 11.10's with 2.6x sixty's. To hit 8.99 I'll need about 250 RWHP (based on a 41-4200lb weight) and a sixty somewhere around 2.2 seconds.
12.4 @ 56 @ 4200lb = 100-110 RWHP/110-120 FWHP
11.1 @ 63 @ 4200lb = 140-155 RWHP/155-170 FWHP
8.99 @ 75 @ 4100lb = 255 RWHP/285 FWHP
using this calc.
The math below says I should pick up about 1.3 seconds and land around a 9.80-9.85 @ 70 mph with a 2.3x sixty. That's 195-205 RWHP/215-230 FWHP, about 40 HP short of where I need to be. Now that said, the math below only accounts for the gear change- not the HP per CI increase from the all-out tuning, the change in rolling resistance, the increase in HP per CI from the methanol injection, the traction improvement of the locker, or the HP per CI increase from the better burn of the MSD ignition. How much HP per CI will it provide overall? Hard to say. That's what the Dyno is for.
The 3.9 stock is rated for 175 hp (192 ft-lb tq) @ 4,800 rpm and 225 lb-feet of torque (137 HP) @ 3,200 rpm. Respectively, that's 0.73 HP/0.8 ft-lb per CI and 0.94 ft-lb/0.57 HP per CI.
Something the calculator can't comprehend/calculate is that in leu of a different HP number, I'm just changing the position and duration of useful torque by playing with the effective gear ratio. I didn't simply bolt-on 40-50 HP to go from 12.40's to 11.10's. I bolted on maybe 15-20 worth, and the change from 3.55's to 4.10's (+15%) made up the other 20-30 worth. The smaller tires make my effective ratio a 5.33 (+30% over 4.10). I highly doubt a linear relationship, but if it is, then that swap should be worth 40-60 mathematical horsepower (Which, BTW, moves the actual requirement closer to 225 flywheel HP).
If/when I manage to kill the V6 (which, theoretically, the factory has it really de-tuned via the cam, so it should be impossible to kill, short of a bearing failure) I'll do a 360 swap or ideally a 408 swap.
C&P from a previous post:
- a. Pump - $140
- b. Nozzle - $27
- c. Tubing - $30
- d. Tank - $11
Goal is an 8.99 1/8 mile so I can run the electronics class. Ideally would be 8.70's for some breathing room on the class cutoff.I have 1.7 harland rockers, clutch fan delete/Lincoln fan mod, SCT can tune, 4.10's, and 265/70-16 tires.
using this calc.
Code:
Assuming the driveline is 83.3% efficient [15% loss is considered the average, I compared chassis dyno and oem ratings to get the 83.3 number] and neglecting rolling resistance due to traction compound and resistance of inertia, My best sixty foot is a 2.606 with the 29" tires and 4.10's [7.503/330 @ 41.80, 12.123/660 @ 55.56 womping] and I have a backup of 2.610/60, 7.282/330 @ 48.95, 11.132/660 @ 62.91. Let's assume my truck weighs 4200 pounds. Force = Mass * Acceleration Mass = 4200 pounds / 32.168 = 130.56 slugs Acceleration = 60 feet in 2.606 seconds = 8.835 feet per second squared Force = 4200 pound-mass * (8.835 / 32.168) G = 1,153.53 pound-force Torque at hub = Force x Distance [radius] Torque at hub = 1,153.5 pound-force * 1.208 feet = 1,393.82 pound-force-feet Torque at driveshaft = Torque at Hub / rear gear Torque at driveshaft = 1,393.82 pound-force-feet / 4.10 = 339.956 pound-force-feet Torque after driveline losses = Torque at driveshaft / 0.85 [efficiency conversion] Torque after driveline losses = 339.956 pound-force-feet / 0.85 = 399.948 pound-force-feet Torque at input shaft = Torque after driveline losses / 2.74 [first gear ratio] Torque at input shaft = 399.948 pound-force-feet / 2.74 = 145.966 pound-force-feet OK, so mathematically, not accounting for external losses, my truck produces 146 pound-feet of torque with 29" tires and 4.10 gears. Now let's reverse all of that and calculate with a 23.5" racing slick and if I remove the 66 pound spare tire and 12 pounds of weight per corner from the smaller tires: 145.966 pound force feet * 2.74 = 399.948 * .85 * 4.10 = 1,393.818 [this shouldn't change since the tire radius doesn't effect it] = Torque at hub 1,393.82 pound-force-feet / 0.98 feet = 1,423.475 pound-force Force = 1,423.475 pound-force = 4086 pound-mass * (X / 32.168) G 1,423.475 pound-force / 4086 pound-mass = 0.3438 G 0.3438 G = (X / 32.168) f/s^2 0.3438 * 32.168 = 11.206 feet per second squared [remember, this was 8.835 originally] Acceleration = 11.206 feet per second squared = 60 feet in X seconds sixty foot time = sqrt(60/11.206) = 2.314 seconds per this calculator -> http://www.wallaceracing.com/etcalc.php actual: 2.606, 7.503, 12.123 @ 55.56 (womping) actual: 2.610, 7.282, 11.132 @ 62.91 calc'd: 2.606, 7.53, 11.83 @ 57.46 calc'd: 2.314, 6.68, 10.50 @ 64.71 If I can beat the calculated by 0.248 at the 330 [3.4% error] and 0.698/5.45 at the 660 [6.27% and 8.66% error respectfully] and those offsets hold true, 6.68 - .248 = 6.432 sec 10.50 - .698 = 9.802 sec 64.71 + 5.45 = 70.16 mph 6.68 * 0.966 = 6.453 sec 10.50 * 0.9373 = 9.84 sec 64.71 * 1.0866 = 70.31 mph So basically, I SHOULD pick up 1.3 seconds and 7.25 mph in the 1/8 mile from the smaller tire
Well I certainly hope you're not on the naughty list this year!
As a joke I threw on my list 4.10 gears. When asked about what they were I explained and my girlfriend damn near took my head off.
Apparently I shouldn't be putting so much money into my truck, but just wait till I get my new sound system in it
2x KickerCVT10 subs
1x Sound Ordnance M1500 Amp
4x Kicker KS60 speakers
2x KickerCVT10 subs
2x KickerCVT10 subs
2x KickerCVT10 subs
Something else that's easy that I might do, is put an exhaust cut-out right after the Y pipe, so it catches the cat's and O2's but not all the tubing and muffler. That's ~$75. I know the V6 has a strange/crappy note, but if it unloads the system a little....
Also need to put a K&N filter in it...another $75.
My wishlist is completely out of control, too:
Front winch bumper w/winch
Parts to rebuild and re-gear 14-bolt rear axle I just picked up
Locker for front axle
Tom Woods CV rear driveshaft with SYE.
Bigger tires
MSD 6 ignition
Harland Sharp roller rockers
I know there's more that I just can't think of right now. I don't even want to add up all the prices because it's too depressing.
Bigger tires
MSD 6 ignition
Add 21-2400 stall convertor to the list, and changing the MSD box to the pricier but better 6520 box. Not a big fan of the price (nearly double what I was going to spend) but it's better for down the road.
With the convertor on the list now, I think that will solidly get me a few numbers dropped off. If I was predicting 9.50's before, I may hit the 9.20's or 9.10's. If I can break the 8's, I'll be happy.
In order of happening:
1. Performance Torque Convertor (21-2400 stall) $325
- a. Pump - $140
- b. Nozzle - $27
- c. Tubing - $30
- d. Tank - $11
3. MSD ignition ($425):
- a. MSD 6A Plus Ignition Box - $300
4. Custom Hemifever All-Out Tune (already paid for)
5. Powertrax No-Slip Locker - $490
6. Slicks and Wheels ($497):
Total: $2,005...after variances, shipping, ect, figure it'll round off to around $2,200.
- a. Pump - $140
- b. Nozzle - $27
- c. Tubing - $30
- d. Tank - $11
aside from the math in the first post... i aint too far behind yall in the wish list exceeding any realistic budget.. so until i can get the funds to do what i want to my rig, im fixin her redneck style... example, i have NO access to a welder (mig, tig, or arc) so im gonna do body work with pop rivets and sheet metal. my rig dont gotta look pretty, its just gotta perform. at the end of this entire project, i want it to have a payload capacity of 12k, but until i can get the motor, trans and rear end swapped out im gonna max this pig out at 6-7k in pulling and towing cap. the stock 00 dak with the 3.9 is just shy of 5k.. i figure with new springs and shocks in the ***, and the *** end geared at 3.92, with the tcase in 4 low, i should have the gearing i need to pull a trailer loaded with 5-6k of weight.. i know i have big dreams, but i already have USDOT #'s and M/C #'s, i just need my rig to be done so i can start making money shipping and transporting regionally in the north east, once my truck is fully completed with new motor, trans and rear end, ill think about going national, or atleast the entire east coast (maine to florida) and as far west as the Mississippi.. and NO before anyone asks, i didnt get the idea to do this from "Shipping Wars". ive wanted to do this waay before that show came out..
now im done ranting.... good luck with your wish lists guys
my wish list
5.9 v8 (gas) or 3cyl cummins diesel
nv4500 trans or 46re
4.10 rear end
boxed and reinforced frame
gooseneck hitch
class 4 hitch (bumper hitch)
LED lights all around
12 head LED Lightbar (Whelen Eng.)
and minium of 64 LED emergency lighting light heads.
and if possible at all, a concealed underlift for towing cars.. making my dak a undercover wrecker...
my wish list
4.10 rear end
gooseneck hitch
Trending Topics
pretty sure the frame wont hold an underlift even when boxed, but a gooseneck should be doable once you box the frame. Class 4 bumper hitch is easy, you might see about finding a NV5600 box from a diesel, I think you can change the bellhousing to fit the gas motors and it has the stronger OD that you can tow in (My friend has a ranch, had the 5 speed NV box in it, always blew 5th gear off the shaft, literally. Put the 6 speed in it and it tows just fine in 6th). Reference: http://www.quad4x4.com/NV5600.htm
edit- 5600 bellhousing for a gasser doesn't exist...but if you go the 4bt cummins route....
make sure you get the 6 speed. i forget what years it came. Else, if you get the 5 speed, weld the 5th gear sprocket and the end-nut onto the shaft.
