Sirius satellite
Old May 12, 2007 | 01:28 PM
dak3.9's Avatar
dak3.9
Default Sirius satellite
Hi everybody, I just baught a sirius reviever last night and i was wondering where other dakota drivers who have satellite radio mounted theirs to and how they did it.
Thanks.
Old May 12, 2007 | 02:28 PM
imnothot02's Avatar
imnothot02
Default RE: Sirius satellite
up the front pillar thru the roof, i do it in the rear, so that in the future if you take it out you wont see the hole...
Old May 12, 2007 | 09:26 PM
Mean Green's Avatar
Mean Green
I think he meant on the inside (ie mounting thereceiver)I would say that the best placeI could find was right below the power adapters on the molding. I had to go to home depot and get a couple Lbrackets and some tiny screws and nuts. Line it all up and drill your holes then pull the molding out some so you can get your hand in to screw the nuts onto the screws, put it all together and enjoy. Bring the piece that the receiver is mounted to so you can get the right size L brackets and I also ended up bendingthe bracketsin order to get the receiver to no point up at a 45* angle...
Old May 12, 2007 | 09:29 PM
crateampsrock's Avatar
crateampsrock
ive got mine above the state inspection sticker, with the wires running down the pilar under the dash.
Old May 12, 2007 | 09:32 PM
crateampsrock
antenna runs through the doom jams above driver side
Old May 13, 2007 | 12:01 AM
Mean Green's Avatar
Mean Green
I hate the suction cup mount it is garbage andI hate having my view obstructed. [:'(]
Old May 13, 2007 | 01:12 AM
RP Racing940's Avatar
RP Racing940
My Kenwood is Sirius compatible. I ran teh antennae wire up from the module to the roof and ran it through the 3rd brake light opening onto the roof. I have a shell so teh factory 3rd brake light is useless and disconnected. Had to silicone a small section so it wouldnt leak. But I cancelled my subscription after 2 yrs. I dont listen to it enough to warrant the $$
imnothot02's Avatar
imnothot02
hah oh sorry bout that mine is in the radio...which is the only way to go...
