Not staying started?
Old May 22, 2007 | 09:57 PM
YerpJustMe's Avatar
YerpJustMe
Default Not staying started?
So I am just getting around to lookin at my truck. When I go to start it, it doesn't want to stay started. I have to keep my foot on the gas to keep it started. Any ideas? Oh yea, I its a 98 and has about 98 thousand miles if that helps any.
Old May 22, 2007 | 10:06 PM
f0x672's Avatar
f0x672
Default RE: Not staying started?
needs a tune up.. plugs, wires, cap, rotor.. possibly bad 02 sensors, run seafoam through the engine as well before u do spark plugs
Old May 22, 2007 | 10:11 PM
YerpJustMe's Avatar
YerpJustMe
I should probably mension that it will stay started after the truck has been running for a little while.
Old May 22, 2007 | 10:15 PM
superdak05's Avatar
superdak05
sounds to me like the battery. these trucks because of the computers need a healthy battery. not like the old days when you could disconnect the battery and the alternator would keep things running. after awhile when its running does it run good or spit and sputter?
Old May 23, 2007 | 12:44 AM
YerpJustMe's Avatar
YerpJustMe
ORIGINAL: superdak05
Its not the battery. Just got a brand new one for it like 2 weeks ago.
Old May 23, 2007 | 01:36 PM
chris1974's Avatar
chris1974
Im with Fox. Do a tune up. Have you ever cleaned your throttle body? Or the TPS?? How many miles are on the plugs??
Old May 23, 2007 | 01:58 PM
Billiam's Avatar
Billiam
What about the possibility of the alternator? If its not working it wont charge like it supose to.
Old May 23, 2007 | 02:04 PM
chris1974's Avatar
chris1974
yeah.....but it starts just fine. It just wont stay running. But then agian-hedid have toreplace his battery......hmmm........[sm=confused06.gif]
Old May 23, 2007 | 06:30 PM
YerpJustMe's Avatar
YerpJustMe
ORIGINAL: chris1974
I only had to replace the battery becuase the truck sat for a while without being ran.
Old May 23, 2007 | 06:32 PM
YerpJustMe's Avatar
YerpJustMe
ORIGINAL: chris1974
I don't know if the throttle body has been cleaned or not. I just recently got the truck from my brother. I was thinking about the TB but I don't know how to check to see if it is dirty or not.
