Engine Roar-No shift until 2200RPM
Old Jul 31, 2007 | 03:52 PM
aiu0462's Avatar
aiu0462
Default Engine Roar-No shift until 2200RPM
I'm new to the Dakotas, have an 02, 3.9L,Auto. After engine and trans are warm, engine still goes to 2200rpm before it shifts out of 1st and 2nd. This is with a light foot. Engine roars and there is a hard shift. Also, driving interstate, cruise set to 75, any small incline, transmission down shifts and rpm's go from 2000 to 3200. Also loud roar. New dist. cap, rotor and new plugs. Milage at 70mph, air on, best has been 17mpg. Any ideas, or is this normal? Thanks in advance for any ideas.
Steve
Old Aug 1, 2007 | 02:35 AM
Spidaman TNMC's Avatar
Spidaman TNMC
Default RE: Engine Roar-No shift until 2200RPM
did u buy this used?
Old Aug 1, 2007 | 09:11 AM
aiu0462's Avatar
aiu0462
Yup. Bought used, with 54000 miles. It's Ext. Cab and I paid $6500. Think I got a good deal because it's mint. Soooooo, what does buying used have to do with the engine roar and milage?
Old Aug 1, 2007 | 09:26 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
any cels???? mine did that but also threw a code i ended up replacing the transmission speed sensor and that fixed it
Old Aug 1, 2007 | 12:38 PM
mdandl's Avatar
mdandl
Check the throttle pressure cable at tb if its binding or out of adjustment it will cause this. there are others too but the cable is most common
Old Aug 1, 2007 | 04:36 PM
DANNYP1964's Avatar
DANNYP1964
my 02 w/3.9 and auto trans has similar symtoms also has a tight accelerator pedal, could it be throttle pressure cable?
Old Aug 1, 2007 | 05:08 PM
aiu0462's Avatar
aiu0462
Thanks Guys! I'll check both of those out in the next couple of days. Will let you know.
Steve
Old Aug 2, 2007 | 02:50 AM
Spidaman TNMC
could have a shift kit..
Old Aug 4, 2007 | 03:46 AM
Mr5150's Avatar
Mr5150
Ya know, I have a 02 3.7 Ram and those things have that damned adaptive learning bs computer and everytime I reset it, I have this problem til it actually shifts. Then its fine.
