Peeps from the Mud!
Old Sep 30, 2007 | 12:17 AM
Pentecostal1988's Avatar
Pentecostal1988
Default Peeps from the Mud!
What is the difference between suspension lifts, body lifts, and leveling kits?
Thanx
-Jake
Old Sep 30, 2007 | 12:26 AM
f0x672's Avatar
f0x672
Default RE: Peeps from the Mud!
suspension lifts pretty much lift up the truck, give you more ground clearance and keep everything nicely tucked under the truckbody, plus give u the opportunity to throw bigger tires on the truck, be careful with the suspension travel
body lifts enable you to throw bigger tires on the truck, giving slightly more ground clearance but nothing as dramatic as a suspension lift, looks good though
leveling kit or with our 4wd dakota, crank up the torsion bars, will get rid of the raked look of the truck and give you even ground clearance up front and back
hopefully that helped u out, others may ring in with more info
Old Sep 30, 2007 | 12:39 AM
Pentecostal1988
thanx man that was helpful indeed!one more question. i have a 3 inch body lift right now ( i did not install it, i just recently bought this puppy and it was already there WITH new 33 inch tires) so anyway my question is...would a leveling kit/crankin the torsion bars do anything at all for me?
Old Sep 30, 2007 | 12:52 AM
f0x672's Avatar
f0x672
its gonna raise your front end and give you a level look, more front end ground clearance, i call it the poor man's suspension lift, makes ride quality somewhat stiffer but i havent noticed much of a difference though what year is your truck?... i have an 01 and all i did was a max of 6 turns, each turn gave me 1/4" lift, i could of maxed it out at 8 turns to get 2 inches of lift but then id have to get longer shocks and brake lines, but yea, pretty much no more raked look
Old Sep 30, 2007 | 01:00 AM
Pentecostal1988
thats exactly what i need! my rear is cool (ground clearnance wise) but with my bull bar in front i really need a bit more
mine is a 2000by the way so how do i go about doin this cranking the bars? i cant afford a good suspension lift so this will have to do for now
Old Sep 30, 2007 | 01:31 AM
Pentecostal1988
http://www.autoanything.com/suspensi...px?kc=MERCSHOP
worth the money?
good or crap?
Old Sep 30, 2007 | 11:17 AM
f0x672's Avatar
f0x672
are you 2wd or 4wd?... 4wd have t bars, 2 wd drives have coil springs, you can only crank the tbars on 4wd models
Old Sep 30, 2007 | 02:49 PM
ryan22's Avatar
ryan22
If i have the 2wd model can i lower the torsion bars in the rear to level it?
Old Sep 30, 2007 | 04:55 PM
f0x672's Avatar
f0x672
you have coils up front, leaf springs in the rear, torsion bars take place of the coil suspension up front, and no you cant ryan, your going to either need to get coil spacers or longer coils for the tront or find a lowering kit for the shackles on the leaf springs in the rear, t-bars connect into the control arm on our 4x4 dakotas since we have independent front suspension and a solid rear axle
Old Sep 30, 2007 | 06:50 PM
ryan22's Avatar
ryan22
can i move the bracket that holds the leaf springs together down to a larger spring where there will be less tension? will that do the trick?
