wig wag headlights
Old Oct 23, 2007 | 11:13 PM
jlking21's Avatar
jlking21
Default wig wag headlights
I am a volunteer firefighter and attempted to install wig wag headlight flashers. when i was done with the flasher off the drivers headlight while set to low beam both filaments were lit until i selected high beam and the low would turn off. the passengers side works fine. does anybody here have wig wag flashers in their truck or another vehicle that might be able to help me?
Old Oct 24, 2007 | 07:51 AM
imnothot02's Avatar
imnothot02
Default RE: wig wag headlights
what brand you have my friend is a volunteer too, he likes to overdress his truck, i could ask him, wheilen parts?
Old Oct 24, 2007 | 11:37 AM
jlking21's Avatar
jlking21
its a galls 3 pattern flasher, thanks
Old Oct 24, 2007 | 07:06 PM
imnothot02's Avatar
imnothot02
somthing isnt wired correctly...
Old Oct 25, 2007 | 12:52 AM
jlking21's Avatar
jlking21
im sure it possible... i checked the headlight wires with a test light to make sure i had the high beam wires. but when i looked into what was causing the problem i disconnected the power from the battery and the wig wag unit was still getting power (coming from the passenger high beam wire even when low beam was on) which is wierd because there should be no power at that wire while the high beams are off. i have e-mailed galls tech support and have yet to hear back in their claimed 24 hour period. any ideas???
Old Nov 1, 2007 | 10:43 AM
teva_feet's Avatar
teva_feet
Old Nov 2, 2007 | 12:22 AM
jlking21's Avatar
jlking21
i got them to work the other day, somehow i mixed up the passenger headlight wires and hooked it up to the low beam wire. but works perfectly now
Old Nov 2, 2007 | 07:50 AM
imnothot02's Avatar
imnothot02
ORIGINAL: teva_feet
idk why ya said it cant be done but yes yes it can,
