rpm's drop in park
Old Nov 15, 2007 | 06:08 PM
godsmack350's Avatar
godsmack350
Default rpm's drop in park
i have a 2001 dakota, lately now that it is cold outside when i put it in park the rpm's drop like it is going to stall[ stalled a few times last year] then returns to normal. it only does this in park and cold weather, runs fine otherwise. any ideas what is causing this?
Old Nov 15, 2007 | 06:12 PM
f0x672's Avatar
f0x672
Default RE: rpm's drop in park
when was your recent tune up?
Old Nov 15, 2007 | 06:20 PM
godsmack350
as in plugs and wires? i havent had that done yet only have about 40000 miles on it. would it need it already
Old Nov 15, 2007 | 06:30 PM
f0x672's Avatar
f0x672
yea, i would definately start there first, in the manual it says like every 30K miles, cap rotor plugs and wires
Old Nov 15, 2007 | 06:48 PM
godsmack350
it is still puzzling why it only does it when its cold our and in park. as soon as it warms up it doesnt happen
Old Nov 15, 2007 | 06:51 PM
godsmack350
i meant when the weather is warm not the truck
Old Nov 15, 2007 | 09:13 PM
ccap's Avatar
ccap
I have the same problem only in reverse and cold weather.No codes show.It's the crank senosor or the cam sensor
Old Nov 16, 2007 | 02:25 PM
godsmack350
how big of a job would it be to replace them
Old Nov 16, 2007 | 05:43 PM
ccap's Avatar
ccap
I just paid the dealer 200.00 you could get a garage to do it cheaper.i just did the crank sensor and it solved the problem.sounds like it would work for you as well.
Old Nov 16, 2007 | 05:49 PM
ccap's Avatar
ccap
you may be able to do it yourself ,but it is in a tough spot behind the motor on top of the bell housing.The part cost about 45.00 from a parts store
