well im a dumbass
Old Dec 12, 2007 | 08:09 PM
f0x672's Avatar
f0x672
Default well im a dumbass
changing the oil in my driveway, worked out the drain plug cause over the years, when my father owned the truck, he brought it to quick lube places to do the work, that damn plug went into the hole 3 different ways, well, tightening down the bolt after i drained the oil, got it right to where it is about to seat against the pan, strips right out, cant remove the plug by back it off, just spins in place, tried a pry bar while spinning it with a ratchet, wont work, plus its 4wd so i would have to drop the axle to remove the oil pan to remove the plug, o well. im sending it to the local shop around the corner from my house, the guy is cool and has been there for almost 30 years, so he must be doing something right... plus i dont have the time to do the work myself, between school, and finals and work * which i had to take off for the next few days just incase this thing takes how long to get repaired... yea they're pissed*... figured you guys would understand my aggrivation better then my other "acquiantences", haha [:@]
Old Dec 12, 2007 | 08:23 PM
englitrob's Avatar
englitrob
Default RE: well im a dumbass
I know exactly how you feel. That moment when you think you get get it a little bit tighter, and you strip out the threads, or that moment when you finaly get that hard to reach bolt out and you drop it into some crevice in your engine bay never to be found again, or my personal favorite, when you leave your favorite wrench in the engine bay while you take your handywork for a test drive, then have to circle the block half a dozen times looking for your favorite wrench, are the times when I wonder why I ever work on my car myself. Then I look at a mechanics bill, and its off to the garage again to spit and curse. The agony and the ecstacy!
Old Dec 13, 2007 | 11:14 AM
klings designs's Avatar
klings designs
When I was rebuilding my vw street bug, I dropped a bolt into the block, Talk about fantastic!!!!!!
Old Dec 13, 2007 | 11:31 AM
Catholic Damage's Avatar
Catholic Damage
ever tear apart a motor, put it back together, and have leftover nuts, bolts, and parts??
Old Dec 13, 2007 | 12:11 PM
User's Avatar
User
ORIGINAL: Catholic Damage
ya... i just tell myself they put extra peices in there for me so just incase i loose one ill have an extra, and in my mind it works out fine.
Old Dec 13, 2007 | 12:27 PM
Catholic Damage
ORIGINAL: User2006
:gets in truck and turns key:
vreoom vroom
BAM!!!
Old Dec 13, 2007 | 12:28 PM
dapirate559's Avatar
dapirate559
ya i lost my favorite 1/4 inch ratchet after i put on my low temp thermostat
Old Dec 13, 2007 | 01:37 PM
f0x672's Avatar
f0x672
yea, ive left tools in our customer's trucks before, its horrible, luckily i always got my tools back cause they stayed in the same place... well good news is, truck is getting towed to the transmission shop tomorrow that rebuilt my 42re, i talked to the guy i said if he can rebuild a transmission, he can pull an oil pan and remove an oil plug, its always my luck i get the really screwed up problems.. my friends " hey wheres your truck".. me " well i stripped out the drain plug and its stuck in the oil pan, just my luck right?"... "dude, stay away from my truck"... nice friends right? haha [&:]
Old Dec 13, 2007 | 07:21 PM
Nicegy525's Avatar
Nicegy525
hmm, Ive found some pretty nice tools left under hoods before! actually I left a nice oil filter wrench under the hood once, only to have the car come back a few months later for another oil change, and it was still there!
Old Dec 13, 2007 | 08:40 PM
spencea15's Avatar
spencea15
My Dads 2002 ram went to get the oil changed at the dodge dealer, my dad pops the hood to check the oil and there is no oil cap on the engine so the dealer has to replace it. About 6 months later we are changing the oil and i see the oil cap in the engine bay well we could not believe we found it.
So later that day we are changing the oil in the dakota and we can not find the oil cap any where so we use the one we found in the ram. I back up the truck and hear something crunch. Somehow the oil cap got under the tire and that was it.
