Help Tranny issue!!
Old Dec 31, 2007 | 07:58 AM
00Dakaota3.9's Avatar
00Dakaota3.9
Default Help Tranny issue!!
Hey Guys, I have a '00 Dakota SLT w 3.9 AT does anyone know how to fix this issue.
P1757 GOV Pressure Not Equal To Target @ 15-20 PSI The requested pressure and the actual pressure are not within a tolerance band for the Governor Control System which is used to regulate governor pressure to control shifts for 1st, 2nd, and 3rd gear. (Zero Pressure Malfunction)
Old Jan 1, 2008 | 11:17 PM
moe7404's Avatar
moe7404
Default RE: Help Tranny issue!!
Moe in Wichita Kansas
is the internal filter clooged? is all the linkage, cables adjusted right? i have seen cable housingsgo bad and stop the cable from moving. is the fluid burnt? does it have the right fluid?
Old Jan 2, 2008 | 05:38 AM
00Dakaota3.9
I don't know, all I know is my wife called me and said that the truck would not go over 20mph and when I got home and checked the code that is what came up. I checked the oil and it was a little low so I added a quart and some STP oil treetment and it shifts ok but still is throwing the same code.
Old Jan 2, 2008 | 09:27 AM
yellowjacket99's Avatar
yellowjacket99
Just to clear this up, you cleared the code after adding the fluid and treatment, and the same code came back?
Old Jan 2, 2008 | 10:05 AM
00Dakaota3.9
No, I didn't. Can I clear it by disconnecting the battery for a few minutes?
Old Jan 2, 2008 | 12:52 PM
yellowjacket99
Yeah you can. I've seen people say to unhook itanywhere from 10-20 minutes.
Old Jan 2, 2008 | 11:17 PM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the Governor solenoid and transducer, and change the filter. Also adjust the bands if needed. Then clear you codes. If you like the diag sheet for code P1757 just send a pm. Leonard
