any1 still use a cb?
Old Jan 3, 2008 | 07:22 PM
imnothot02's Avatar
imnothot02
Default RE: any1 still use a cb?
exactly you know repeaters... 10m radio...
Old Jan 3, 2008 | 07:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
not really but im going to look it up now lol
Old Jan 3, 2008 | 07:39 PM
imnothot02's Avatar
imnothot02
type in amateur radio..
Old Jan 3, 2008 | 08:10 PM
mikec04's Avatar
mikec04
No CB here. Didn't know anybody still played with them.5 watts output-am. Got Icom 2meter FM-5-25-55 watts out thru a glass mount antenna on back window.
Have had ham license for 15 years-
N9TNL
Old Jan 5, 2008 | 01:51 PM
w9awx's Avatar
w9awx
I'd be careful as using any radio on the amateur radio bands without a proper amateur radio license, could net you a $10000 fine. The Fcc just loves to make examples of cb users who modify their radios for out of band use. Amateur Radio operators love helping the Fcc in finding people who do that. The Fcc recently came down hard on many cb radio manufacturing companies as well as dealers for selling cb's that could be modified or that had been modified for out of band use. Gregg
Old Jan 5, 2008 | 02:47 PM
magnethead's Avatar
magnethead
I have an OLD unit in my dakota, had it in the dually before. Has 3 weather bands plus CB and the little 2 ft antenna from walmart. Mounted the CB in the front bench jump seat (nothing else fits there, why not?) so the center console can still close down fully (you cant tell I have a CB), got a cig lighter adapter fom rat shack and ran the power leads to it (again, when unplugged, you can't tell I have a CB), then ran the antenna feed through the hinge in the back of the console to the back seat, where i have the antenna sitting next to the back seat sandwiched between the seat and wall on the drivers side. (again, you cant tell it's in there)I get decent coverage for being inside the vehcile and down low.
Old Jan 5, 2008 | 04:37 PM
shrpshtr325
THE ULTI-MOD
wow that sounds like a good setup might have to look into somthing discreet like that but i dont have a back seat to work with the durango is all open so ill have to find some other way to hide it
Old Jan 5, 2008 | 05:10 PM
bbcrack's Avatar
bbcrack
i hav a 30 year old laffeyette cb hookd up 2 a cheap magnetic antennia that sits on da bedrail. i slide the radio under my seat&just leave it chilln on da floor if im using it. i also use the cigg lighter plug from radioshack. nothins permainate because i ran the cable out the passenger side door & up between the cab and bed. no drilling yet. i was lookin for somethin compact that i could mount permantly. just wonderin what yall use.
Old Jan 5, 2008 | 06:22 PM
LAKOTA169's Avatar
LAKOTA169
Got my first CB in '64, a 6 channel chrystal controlled Sonar. Back then, there was hardly anyone on the air. In the '70's had sets in both custom vans plus a base in the house. The one in my van would dead key @ 200 Watts and talk at 175 Watts. Haven't used a cb since the 70's. Still have 3 or 4 mobile sets and the base around here somewhere. All 23 channels. Couldn't see much use in 40 channels when i only used 2 or 3.
Old Jan 8, 2008 | 12:54 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: shrpshtr325
i was considering a handheld one, but then thought that the range on them would probably suck so i havnt gotten one ive got a set of 2way radios with a rediculus range on them that we use on car trips
i've got a couple of the GE hand helds that i bought on ebay for about $15. they will work line of sight up to a few hundred yards. they'll do a little better with an external antenna up on the roof. the only real problem with them is the clutter of wires once you get a cig lighter plug and antenna both attached, and you have to pick up and hold the cb and wires when you use it. its ok, but a mounted unit is a LOT better.
