High Idle On Cold Start???
Old Jan 15, 2008 | 01:13 PM
tcndeb's Avatar
tcndeb
Default High Idle On Cold Start???
The truck idles at about 3000 when cold. Idles fine when warm. IAC? I've never had one idle high before. Usually they idle low when going bad. TIA.
Old Jan 22, 2008 | 03:51 PM
tcndeb's Avatar
tcndeb
Default RE: High Idle On Cold Start???
anyone know how to troubleshoot the IAC?
Old Jan 22, 2008 | 06:50 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
idk if the 3000 was a typo but lately mine has been idling at about 1000 rpms at first start up, its normal jsut the computer trying to warm up the engine, once its warm the computer lowers the idle to save fuel
Old Jan 22, 2008 | 07:36 PM
klings designs's Avatar
klings designs
it will idle high in the cold, but 3 is a little too high
Old Jan 22, 2008 | 08:48 PM
imnothot02's Avatar
imnothot02
3 grand?!yea how long since a intake tb iac ectc clean?
Old Jan 22, 2008 | 09:01 PM
dhvaughan's Avatar
dhvaughan
it should idle around 1000 when cold, about 600 when warm. anything else is a bad iac. while it is a good idea to clean the TB and the iac port on the back (with iac off), when the iac has malfunctioned (like yours has) i think its a waste of time to clean it. just replace it. when it goes on the blink, the little motor and feedback circuit has gone bad. cleaning won't help.
Old Jan 23, 2008 | 07:39 AM
tcndeb's Avatar
tcndeb
not a typo. it's idling a 3 grand when cold. I pulled the iac and cleaned everything up, but no luck. that's why I was wondering about a troubleshooting procedure to verify that the iac is fried before I replace it. I've seen guides for other makes of cars, but not Chryslers, and I don't have a shop manual for this truck.
Old Jan 23, 2008 | 07:48 AM
shrpshtr325
THE ULTI-MOD
ok the best i can give you on that is that if when you pull the IAC out it should move in and out freely, if it doesnt then its going bad, should take a little effort but not much, and it really is a cheap part like $20 or $30 at your local auto store, not hard to change either,
p.s. when you put it back in after moving the plunger in and out you will need to be on the gas to start the truck, and it will die when you let off the gas, the second time you start it, it should be fine
Old Jan 23, 2008 | 07:38 PM
imnothot02's Avatar
imnothot02
have you reset the ecm after the tb cleaning?..., also if you change the iac, reset the ecm the truck will re-learn..also check the tps sensor, SHOULD be at .3-.8 at idle, (do this by going center pin of tps to ground)
id reset the computer first...
