Anyone else ever get a p0420 code???
Old Jan 30, 2008 | 02:34 AM
bpm's Avatar
bpm
Default Anyone else ever get a p0420 code???
I keep gettin this code and am wondering what others have done to cure it??? I'm runnin reg. octane fuel...I dont have access to a decent scan tool to see what the O2 sensors are doin,but bein this code showed up,I'm thinkin its the gas or I need new mini cats...which brings me to ...has anyone replaced theirs,is there an aftermarket y-pipe w/ or w/out the cats,maybe I could fab. one and relocate the sensors to a single high flow???
Old Jan 30, 2008 | 02:46 AM
jarebear86's Avatar
jarebear86
Default RE: Anyone else ever get a p0420 code???
Catalyst System Efficiency Below Threshold (Bank 1) thats what that code means
Old Jan 30, 2008 | 02:59 AM
bpm's Avatar
bpm
Yea, I know the code discription,I just don't know why I'm gettin it...thanks anyhoo...just wonderin if anyone else has gotten this one repeatedly and what they did to fix it...
Old Jan 30, 2008 | 03:55 PM
scandal669's Avatar
scandal669
i just started getting that too...it is either the catalytic converter going out or the oxygen sensors...both cost about $300 to replace. from what i have heard, the truck will still run fine but you will lose some mpg's is all. when i get some money together i will take it somewhere so they can narrow it down to one or the other. also, from what i have heard is that about 70% of the time it is usually the catalytic converter and not the o2 sensor...hope this helps
Old Jan 30, 2008 | 11:01 PM
rred's Avatar
rred
i just had my cat replaced for free. fell under dodges warranty. didnt pay a peny. the emissions and computer are still under warranty on my truck. it goes to 80,000 miles i believe. i have 65,000 now. call your local dodge service dept and check if you think that the issue.
Old Jan 31, 2008 | 11:43 AM
bpm's Avatar
bpm
Unfourtunately, mine has around 110,000...and bought used...[:'(]
I goota look into gettin the y-pipe and after cat replaced with some perf. parts!!!
First I need to make sure thats whats wrong,although it's somthin I wanted to do anyway...
Old Feb 1, 2008 | 02:46 AM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
I have had this code for about 2 months now. I just hook up the scan tool and clear the code, and it stays off until i do a lot of city driving. I have not noticed that it cuts down my mpg's (still get about 21 hwy mpg.) I hae not replaced anything yet because it does not seem to be effecting the truck and i also don't want to spend the money i don't have to.
Old Feb 1, 2008 | 11:45 AM
scandal669's Avatar
scandal669
what type of a scan tool do you have to clear the check engine light? is it expensive? i dont want to go spend $200 on a tool when i could spend just a little more to actually fix the problem...thanks
Old Feb 1, 2008 | 12:10 PM
Chris's Avatar
Chris
Replacing your cat and O2 sensors will pay for your scan tool with returned MPGs.
Old Feb 1, 2008 | 07:20 PM
Ethica19's Avatar
Ethica19
hmmm, my cat was 60 bucks, it's a magnaflow. My 02 sensors are Borg Warner together they were 25 bucks on E bay. I paid 30 to have the cat installed.
